Home > My Defender > Tonga green TD5 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4788 |
Looks great
Glad to have helped you spend your money 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
16th Dec 2019 10:34pm |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 |
Cheers Clayton and Grafty!
Black wheel nuts will be on their way soon. Just didn't get round to it. Currently prepping the car as I have got it booked in for a full dinitrol treatment at the start of January. Debating whether or not to get the outside of the cross member treated with dinitrol at the same time along with the tow pack as it would save me time and money. But I do like the look of the painted rear cross member currently. Instagram - @Land_Rover_Defender |
21st Dec 2019 11:32am |
So today consisted of stripping the rear mat out and giving it a good clean. Removing the seat belts was a pain due to the bolts underneath. Removed the dog guard also, gonna decide if I want this or not, I think its a good addition and is so easy to put in.
The rear mat is tired and old, so if anyone wants this then please make me an offer on it, it has some holes drilled into it where things have been previously. I will be replacing it, DM me if you want it. Rear bulkhead bar to go in soon also! Click image to enlarge Click image to enlarge Click image to enlarge Instagram - @Land_Rover_Defender |
22nd Dec 2019 4:45pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10817 |
Good news on the black nuts Greeny 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
23rd Dec 2019 8:50pm |
Been busy this weekend with the TD5. EGR deleted and replaced with the bypass kit. New injector harness and tappets adjusted
Spent today stripping out the interior and cleaning everything! I am probably being fussy but I do like a clean car, especially when it has got someone else's dog hair in it Click image to enlarge Click image to enlarge Click image to enlarge Who doesn't like a clean battery box? Click image to enlarge Instagram - @Land_Rover_Defender |
29th Dec 2019 5:44pm |
Good being fussy there Greeny, i would have done the same as you with a good thorough clean 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
30th Dec 2019 8:58pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4797 |
Nice attention to detail Greeny 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
30th Dec 2019 9:18pm |
Cheers guys! Will clean the back out and then stuck some sound proofing down on the back (cheers Grafty for the tip!) along with a genuine load mat Instagram - @Land_Rover_Defender
30th Dec 2019 10:11pm |
Update on the Tonga Td5.
Done a fair bit of work on the car over the last month. I took the car to SouthWest Rustproofing to have the chassis sprayed in Dinitrol. Can't recommend them enough, they did a fantastic job. The old waxoyl that was on the car was a mess and they prepped the car by removing all of this properly to then give a good coating of dinitrol (see photos before and after). To my surprise I needed a new rear crossmember which was annoying, the old waxoyl was hiding a few holes on the underside and I am now glad that it has been replaced properly and treated with dinitrol (cant be sure what is hiding beneath nasty waxoyl!). The chassis now looks like new. I had a new fuel tank guard, brake pipes and some other bits which were old. So that is the chassis sorted for a good few years! I will be returning to SouthWest for an annual inspection and top up. Discovered that I needed a new exhaust. I was planning to get a new one anyway because I wanted a straight through so this was just an excuse to do it now. I opted for a full stainless Twisted Automotive pipe. Removed the gearbox crossmember easily, with the bolts coming off no problem and there being no rusted on the chassis rails which was good news! Cut the old exhaust off and then fitted up the Twisted one. No issues with fitment, it was a perfect match. All stainless bolts used on the exhaust and stainless bolts on the gearbox crossmember. The exhaust sounds fantastic and is more responsive. Few body bits to sort out next, I have just finished spraying the wheel carrier and tow pack. I will be spraying the crossmember in Tonga green so thats next on the list. Lots to do still! See photos below. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Instagram - @Land_Rover_Defender |
9th Feb 2020 5:25pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3685 |
My you have been busy! Which product did you use for the under seal?
9th Feb 2020 6:10pm |
The chassis has been treated with Dinitrol. First it was steam cleaned, all the old waxoyl removed with tools etc. It is then sprayed with Dinitrol rust converter all over. The inside of the chassis, doors and bulkhead are sprayed with Dinitrol wax, the outside of the chassis is sprayed with Dinitrol 4941 and then Dinitrol stone chip 445 is used on areas which need a harder coating like the tow pack and arches etc. Dinitrol is a great product, really happy with the results, much better than waxoyl! Instagram - @Land_Rover_Defender
9th Feb 2020 6:16pm |
Very tidy work, who made the exhaust? Looks nice workmanship 2015 HT XS 90
9th Feb 2020 7:20pm |
SuliSuli the exhaust is from Twisted Automotive Instagram - @Land_Rover_Defender
9th Feb 2020 7:40pm |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
Good work Greeny! What are your thoughts on the exhaust? How does it sound? I've currently got a TD5 with a straight through mid-pipe and decat front section but it's starting to crack/rot etc so looking for a more robust solution and can't decide between Twisted and Alive offerings. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
10th Feb 2020 6:50am |
