Home > Puma (Tdci) > Converting 2.4 TDCi to 'normal' oil filter? |
Mago Member Since: 25 Apr 2021 Location: Frankfurt Posts: 27 |
That is the filter itself, but thank you
The Part No for the whole housing seems to be BK3Q 6B624-CB Greetings, Defender 110 TD5 Defender 110 Puma 2.4 |
22nd May 2021 9:25am |
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 |
Yes exactly, BK3Q 6B624-CB is the number for the housing.
24th May 2021 7:51pm |
PeeWee Member Since: 13 Apr 2017 Location: Somersetty Posts: 19 |
My local mechanic has just changed my plastic housing assembly for a spin-on assembly. Whilst the assembly (from LR) isn't cheap, it was easy to fit. Start to finish including taking numerous phone calls and a test drive, less than two hours. He bought from LR because Bearmach etc had no stock. Oh stuff!
The logic for making the change was two-fold. Firstly I am oldfashioned enough to think that a smaller filter is nowhere near as good as a larger one, hence the engine should (?) last longer. Secondly, I was getting fed up with earache about the small black stains on the drive! |
18th Jan 2022 8:31pm |
Ecco Member Since: 31 Oct 2015 Location: Kuala Lumpur Posts: 280 |
..i do change oil and filter every 5-6K km, and after reading this, im wondering, am i paranoid? What are your engine oil change interval folks? |
26th Jan 2022 3:01am |
