![]() | Home > My Defender > Puma to LT1/8L90 Restomod |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 ![]() ![]() ![]() |
I can't help with preload figures I'm afraid, I've always used the twin-nut setup and adjusted until there is no/very little discernible play at the edge of the tyre when rocked.
As for the ABS sensor bushes, I should have a pair that came out of my axle. Drop me a PM if you still need them. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
mrfirepro Member Since: 06 Nov 2020 Location: kent Posts: 233 ![]() ![]() ![]() |
Update on the ABS sensor, they do need a bush for the rear axles (thanks for the help Martin) and it's not the cover that comes with the sensor. I'll post up a pic of the part when I get it.
I'm getting a real run around from the break kit suppliers, as they still have not put right the kit they wrongly supplied ![]() On a more positive note got some of the plating coated and some other parts ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge finished the fuel tank arrangement and got the tank installed ![]() Click image to enlarge I have decided to opt for dash 8 fuel lines even though it seems all the modifiers use dash 6. Hopefully the bulkhead is going to get some colour today ![]() Click image to enlarge have started to bolt items onto the chassis as well ![]() Click image to enlarge |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 491 ![]() ![]() |
Dont forget to seam seal all the bulkhead joints/seams before top coat, what fuel pump did you use? The LT likes to run a PWM type pump for direct injection.
Hi Linds, thanks for your comments
I asked the guy who is doing the bodywork to make the seamsealer look as close to OE as possible, his reply was that he wasnt sure he could do it that badly, made me laugh. The fuel pump is a Deatschwerks DW200 In-Tank Fuel Pump 255lph ![]() Click image to enlarge |
Yes I agree with him but there are some sizeable gaps between spotwelds! We generally use a coating of Raptor followed with a coat of Lizardskin acoustic then a coat of Lizardskin thermal barrier then the top colour coats. Have you had that pump recommended for the LT? They usually need a constant 75psi and high flow to feed the high pressure pump
I've chosen that pump for several reasons the first being the LT requires 170LPH at 72psi to the HP pump, The DW200 produces 90 psi at 170LPH and is good for over 200LPH at 72 psi.
The DW is also an in tank (I prefer this over a suction, due to complications with lift etc) and is a very good fit for the OE sender unit. I could not find another that was such a good fit all round. I'm not sure what pump others are using as I didn’t find much info on this topic. I am very happy to look at alternatives if there are pumps better suited. The only issue I do have is that I'm running fuel line sized to run a future blower, however this pump is unlikely to be suitable if I do go down this route in the future. Thanks for the advice on the seam sealing. |
I could be wrong but I think the minimum spec was the DW300 pump? Aeromotive do a nice Phantom in tank kit but its designed for a steel tank really but may work with the plastic tank. You may also have to think about a auxiliary tank on a 90 as the range is very restricted when running in anger. It will be interesting to see what the fuel economy is like with the LT as GM claim high 20s for midsized pickups!
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 ![]() ![]() |
My god
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3690 ![]() ![]() ![]() |
Hi 20’s?!! If that’s the case where do I sign up! |
Yes the old generation LS engines were already more fuel efficient than any RV8 admittedly not a major achievement! But the LT Gen 5 engines benefit from direct injection and variable valve timing making them not only more powerful but also more efficient. The only downside is they require regular intake port/valve cleaning to prevent coke buildup a problem shared with every direct injection petrol engine until recently.
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 169 ![]() |
I believe the later LS and the LT engines also have 'active fuel management' - when you are at light throttle / cruise they will shut down cylinders (no spark / injection) and effectively half the active displacement and reduce the fuel consumption.
very good discussion points and great input
![]() Fuel Pump - I did consider the DW300 but iirc it was around 280LPH at 72psi. I'm not going to install the tub until last thing so hopefully I'll identify if there are any fuel issues before access will be a problem. LT1 crate engine - for maximum efficiency direct injection and coils per cylinder but sadly no Cylinder deactivation ![]() "Cylinder Deactivation - Not Used With Chevrolet Performance Engine Control Kit This engine is used in the Generation 6 Camaro. In production, to provide maximum fuel economy under light load driving conditions, the engine control module (ECM) will command the cylinder deactivation system on to deactivate engine cylinders 1, 7, 6, and 4, switching to a V4 mode. The engine will operate on 8 cylinders, or V8 mode, during engine starting, engine idling, and medium to heavy throttle applications. This system requires many inputs (weight of vehicle, tire size, fnal drive ratio, etc.) to work properly. These parameters are unknown when selling the Chevrolet Performance engine controller kit. Due to these unknown parameters as well as the need to tune the motor mounts and exhaust system for operation in both V8 and V4 modes. The Chevrolet Performance engine control kit disables this feature. The engine has not been changed, so cylinder deactivation hardware is still present." Fuel Tanks - it's great this topic has come up ![]() I'm nowhere with this and would welcome advice, I was looking to add the plastic auxiliary tank in the O/S wheel arch but that’s not possible (or at least I don’t think so) as a clash with the rear seat bracket. My next thought was to add a second tank (which I would fabricate) and connect it to the bottom of the existing tank (with plastic welded spigot added to the bottom of the tank) but was going to look at this later when I've located the tank for the air suspension and can assess where there is going to be room. Any solution I look at has some serious issues to overcome. Any other ideas?? |
Ive fitted the plastic under arch tank and they are a pain to fully seal the lower balance pipe to the original plastic tank. The original tank has no perfectly flat sections to seal onto. About the only free space you could gain would be to lose the drivers under seat locker and move the electrics to the other side battery compartment. There is plenty of wiring length as the loom comes over from the LH side anyway. It would have to be a balance fill from the main tank unless you had a transfer pump arrangement.
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
I am getting about 12mpg with my v8 which equates to 180/200miles a tank. Standard puma 90 plastic tank. 1989 90 4.3 V8
2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf |
