Home > My Defender > What Did You Do In Your Defender Today |
Mrs Greeni got her vanity mirror
16th Sep 2011 10:53am |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
that is smart. Mrs BM asked for one as well. i just bought a £5 square replacement wing mirror glass and stuck it on the inside of the visor BM52 |
16th Sep 2011 12:11pm |
It's off a Smart car, found it on eBay Probably a good modification, if you ask her ! |
16th Sep 2011 1:06pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
Not an issue seeing as I have no intention of selling it. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
16th Sep 2011 4:26pm |
No DC100 for me, will probably get an Amorak if it will tow 3.5 tonnes. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
16th Sep 2011 4:27pm |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
Took the old girl in for her 48k service. The gearchange is now a lot smoother, but there is a large dent in my wallet
16th Sep 2011 6:07pm |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 |
Better get your speedo looked at 22900013A, cause this makes it look like you took that photo going at about 60mph :lol: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 15 plate 2.2SW XS |
16th Sep 2011 6:18pm |
casher Member Since: 17 Sep 2010 Location: Glos Posts: 58 |
same with me, except its still the hassle of filling it up all the time! i just ram the fuel cap in the pump trigger and it fills itself up! |
16th Sep 2011 7:00pm |
I certainly wish it had a bigger fuel tank to cut down on time wasted at the pumps... 2011 110 USW
16th Sep 2011 7:08pm |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 |
Daft question, but don't any of you fill up on the "Lorry forecourt"?
Usually there is a pin on the pump, so you don't have to hold the trigger. The flow rate is a lot faster than a normal pump too. I usually do this, if it's quiet. Just a thought |
16th Sep 2011 7:46pm |
I often do, but havn't seen a pin. They can be a pain as you have to show your method of payment up front (after queing) then fill up, then queue again, then pay...and the pumps are so powerful it goes all over the place. In the owners handbook for my vehicle it specifically states NOT to use the HGV pumps. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
16th Sep 2011 7:48pm |
Ah, didn't realise it said that in the tdci's handbook....don't have to worry about oat like that in my 200
16th Sep 2011 8:14pm |
ive seen people put bits of wood, but the fuel cap fits perfectly to hold the trigger!
16th Sep 2011 8:49pm |
A mobile phone, depending on how brick-ish it is, can work too... but don't let them see you doing it!
16th Sep 2011 8:52pm |
