Home > Modifications & Maintenance (L663) > BREMBO 6-Pot Brake Upgrade
Page 1 of 5 12345>
thepetrolhead
United Kingdom 2003 Defender 90 Td5 CSW Oslo Blue
Anyone upgraded to BREMBO front brakes, calipers, discs?
As fitted to V8/P400.
Does anyone know if these are the same part numbers as RR Sport. Look the same.
RR Sport Caliper
Land Rover caliper. FFRR?
L663 20" alloys
L663 22" 5098 alloys
Post #891354 14th Mar 2021 2:23pm
jon_a5
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Montalcino Red
Don't quote me on this as I don't have any real evidance only what people have said to me, but I was under the impression that the Land Rover branded brakes are still made by Brembo it's just Brembo changed their strategy and Manufactures started branding the caplipers instead.
Post #891358 14th Mar 2021 2:37pm
thepetrolhead
Part numbers
I have the following part numbers.
RANGE ROVER L405 SPORT L494
OEM LAND ROVER RED BREMBO
PART NO: 20A6470500 / 20A6470600 / LR139244
OTHER REF. NO. LR049115 / LR093886 / LR049117 / LR093886
Was hoping someone would be able to confirm that they are the same part as fitted to L663 Defender.
I have a friend who is checking. If I get confirmation, I'll update this listing.
Whenever I eventually get my new Defender L663 Hard Top, I want to upgrade to BREMBO front brakes. As fitted to P400/V8.
I suspect, someone has already done it.
Post #891421 14th Mar 2021 7:56pm
SCP73
@thepetrolhead
I would certainly be interested in the MY22 P400e red version. They do look really good behind black/grey wheels.
Certainly an upgrade SWMBO has said she would like. 1992 - Defender 90
1997 - Discovery
2015 - Disco Sport (only 1 child)
2018 - Merc V-Class (3 Children and the mutt)
2020 - Ordered 110 X-Dynamic HSE MY21.5 (hoping big enough for the family)
2021 - MY21.5 Cancelled by JLR, MY22 ordered, awaiting dates :/
Post #891453 14th Mar 2021 11:27pm
thepetrolhead
Yes. My 21MY also "un-slotted" by JLR.
Now MY22 with some additional options.
Still awaiting new build date.
Post #891474 15th Mar 2021 8:40am
Babadook
Switzerland
22" has big caliper 6 pot with front 380mm disc and back 365mm
20" has normal caliper 4 pot with front 365mm disc and back 350mm
Post #891511 15th Mar 2021 10:33am
thepetrolhead
Update on part numbers.
I have been told these are the same
Part Number as L494 Range Rover Sport.
Please check before ordering.
When I do mine, I'll update the post.
Post #912628 16th Jul 2021 6:55am
Andy S
Can the standard Defender caliper bracket be used or is there one specifically for these calipers?
You can buy refurbished one's off Fleabay but it's the brackets that may need investigating unless you know otherwise.
Post #912710 16th Jul 2021 5:10pm
thepetrolhead
Got a Land Rover tech friend investigating.
Will update will all the part numbers once known
Post #913126 19th Jul 2021 5:57pm
Andy S
Any news on this yet?
Post #915939 7th Aug 2021 4:48pm
jackie
Sorry to hijack this thread….
I am thinking to go for D250. However, since it comes with 2-piston caliper with 349mm disc. I don’t know if it is sufficient to stop the 2.4tonnes defender. So, for existing D200/D250 owners, can you advise if the stock brake is good or I shall opt for D300 which has 4-piston caliper instead?
Thanks
Post #916370 10th Aug 2021 4:00pm
J77
The brakes are pretty fierce, they are more than up to the job. 24MY 90 D250 HSE, Tasman Blue
Post #916394 10th Aug 2021 6:15pm
Tim in Scotland
More than sufficient on my D240 - they can take a bit of getting used to as they are very sensitive but I’ve no complaints about their stopping abilities - miles better than the brakes I had on both the L322 Range Rovers I’ve owned. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #916402 10th Aug 2021 6:56pm
jackie
Thanks a lot for the prompt response.
Just a bit curious the difference between D250 S and D300 SE. The difference in $ is £6000. I only see the D250 is 50bhp down, smaller brake and a bit of interior difference. Why is the difference so huge in price?
Still deciding between the two and don't know if I shall spend £6000 more for D300 SE.
Post #916437 11th Aug 2021 1:44am
J77
Land Rovers greed.
I went with D200 because I couldn’t justify spending an extra 3 or 4k for 50hp. 24MY 90 D250 HSE, Tasman Blue
Post #916457 11th Aug 2021 9:41am
Page 1 of 5 12345>
