Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD
Page 8 of 19 <123 ... 789 ... 171819>
spudfan
Ireland
Are we still using the word "intelligent"with this set up?
...Just to lighten the mood Smile 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #890512 10th Mar 2021 5:52pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
Well no updates yet but they have done 4 rolling test drives in the last 24hrs and the last one being the longest. Car doors are currently open so they must be working away on it.
Post #890764 11th Mar 2021 3:25pm
I like the remote oversight feature. đź‘Ť
Not sure it helps in that it's different vehicles, different engines, etc but it is JLR AWD fault reported as " '2 Wheel Drive Only Traction Reduced' message is displayed on the Instrument Panel Cluster (IPC) and the cause was found to be "A missing cable tie on the transmission electrical wiring harness on All Wheel Drive (AWD) vehicles "resulting in "Transmission Electrical Wiring Harness Chafing on Rear Driveshaft".
Post #890765 11th Mar 2021 3:29pm
90 Dreamer
not that far from me, I'm just at the other side of the "angel".........
Post #890770 11th Mar 2021 4:07pm
Digger2000
It’s good but unfortunately that isn’t working properly either Rolling with laughter the vehicle faults don’t show up in it.
Just had a call from Land Rover solutions they said the head engineer is working on the car now, looks like they will be working on over the next few days. She mentioned something about a wiring bracket but that wasn’t from the head engineer so wasn’t sure if it was still relevant to the problems with my car. She said the engineer would ring me with an update and she’s going to monitor the progress and ring me next week to see if everything got resolved.
Post #890780 11th Mar 2021 4:48pm
Digger2000
I think this must be what Land Rover solutions were on about with the wiring bracket! 👏🏻👍🏻
Post #890781 11th Mar 2021 4:51pm
spudfan
Ireland
All of the fancy stuff fails short due the a missing cable tie. At least the missing cable tie would come under "a mechanical" issue and therefore easily sorted...once the issue is identified. This should be good news for other owners. At least JLR know now what causes the issue and how it can be sorted. The cable tie once attached during assembly short stop this issue occuring. 1982 88" 2.25 diesel
Post #890794 11th Mar 2021 5:58pm
Digger2000
Yes hopefully easy fix but I’m still worried if there has been any lasting damage to the differentials and what was going on with the low engine coolant? I still need a lot of answers from the dealership engineers before I’m comfortable driving this car again. They should of done a rolling test drive from the start I hadn’t done any long distance drives back then and the damage done if any would of been minimal but after they said the problems are because I hadn’t taken it on a long drive the next day I took it 75 miles into the countryside and that’s when the problems got worse to a point the LR assist engineer said the vehicle has to come off the road immediately. Next few days are going to be interesting that’s for sure.
Post #890796 11th Mar 2021 6:11pm
DSL
Good to see LR is still blaming their customers. Thumbs Up
Rolling Eyes
Post #890800 11th Mar 2021 6:41pm
Digger2000
Wow I have just seen in the all new Defender owners group on Facebook that someone else is reporting no engine coolant! Collected his car in February like me and similar mileage 250 miles on the clock. I would highly recommend everyone checks their engine coolant level ASAP as mine didn’t show any warning messages for the low coolant.
Post #890880 12th Mar 2021 8:23am
About that noise you keep hearing...
Post #890997 12th Mar 2021 6:24pm
Digger2000
Just sent that to the dealership service manger Rolling with laughter
Post #891004 12th Mar 2021 6:39pm
Digger2000
No updates today other that they have closed the windows and locked the car after leaving them open last night. They must be waiting on parts before they can progress with the repairs.
Post #891005 12th Mar 2021 6:42pm
spudfan
Ireland
More than likely we will see a new post here along the lines of
"Hello, I am a new owner and I am experiencing the following problems...... Any ideas as to how to remedy them?" Whistle 1982 88" 2.25 diesel
Post #891014 12th Mar 2021 7:43pm
Digger2000
The person on Facebook that had the low coolant warning has the P400 engine
Post #891018 12th Mar 2021 8:03pm
