Home > Modifications & Maintenance (L663) > Fold down table.
Page 3 of 4 <1234>
keith
Had this exact table in the shed for 2 yrs. still not on Rolling Eyes
Keith
Post #890485 10th Mar 2021 3:52pm
SN
DSL wrote:
I suspect those bits in the box are all the Jeep parts. Whistle Whistle
Correct! Actually Defender parts are winning as I have set of deep rubber mats in a bigger box and a set of big rubber O's currently sat 37 miles away... Laughing Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #890496 10th Mar 2021 5:00pm
Flapjackpatriot
United States
Got mine setup this weekend with some brackets from my local hardware store, very straightforward install. For those wondering your bracket needs to extend .75 inches (19mm) on either side of the table arm for a perfect fit. Thanks GR41!
Post #891456 15th Mar 2021 12:26am
Tim in Scotland
Finally done it with a couple of modifications so I didn’t need the L brackets - I used some longer Torqx bolts, some polythene spacers (both from Amazon) and an old bungee sail tie as I cannot use the feeble clips that are supposed to keep the table in the stowed position. I have two other mods I want to make - see if I can mount my fire extinguisher bracket on the stowed table and also find a way to mount my first aid kit there too (both live under the boot floor at the moment, so out of sight if there is an emergency, nobody will find them)
Please bear in mind I have basic tools, two left hands and zero technical ability and this is the first time I have unbolted/ modified anything “major”(to me} on any car I’ve owned............. I had one finding when unbolting the factory Torqx bolts - they seem to have been fixed in with something like Loctite and needed a little effort to undo so I may need to apply more adhesive if things start to vibrate loose........... Big Cry
Hinge spacers
Door anti-vibration mod
Closed against the stops
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #900368 28th Apr 2021 2:10pm
darlas890a
United States
I like the way your table fits. I wanted to do the same. What parts did you use and where did you get them?
Thanks
Post #916147 9th Aug 2021 3:04am
SN
There are a couple of options to fit the table - Tim's above swaps the ends over and uses some spacers in the hinge mount (but needs an elasticated strap to hold the table shut) whereas mine uses L brackets to keep the ends the right distance apart so that the latches still work (as per OP's solution) but the original stoppers are a bit short
But mine is now non-rattly after adding a pair of dining room chair feet onto the 'too short' rubber stoppers
Original stoppers too short...
New stoppers
Stoppers fitted (literally push fit over original stoppers)
Nice and snug when shut - this shows how the angle brackets are used with bolts in the original holes in the door
Amazon links for table and brackets/bolts can be found in the posts at the top of this thread
These are the stoppers I used - 19mm variety
https://www.amazon.co.uk/gp/product/B00TS9...&psc=1 Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
Post #916160 9th Aug 2021 8:28am
Waldorf
Belgium 2008 Defender 130 Puma 2.4 HCPU Stornoway Grey
It seems to be a popular mod, it's currently unavailable. Sad
Post #916742 13th Aug 2021 1:52pm
Sepp
Germany
There is approximately half a dozen different suppliers for this kind of fold down table at Amazon, took my less than 10 seconds to find some available ones...
Post #916753 13th Aug 2021 2:29pm
G4R1
After going through your installation options. I decided to do a little modification that allows quicker folding and unfolding of the table and 0 rattles in the closed position. Also, get rid of the flimsy latches.
This is the locks I used https://www.amazon.co.uk/gp/product/B08JCY...&psc=1 3.0L MHVE D200 S Pangea Green+Black Pack
Adv. + Off-Road and Family Packs
Post #916795 13th Aug 2021 6:49pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Those catches look great, do they screw into the existing screw holes in the door or have you drilled and screwed them in? Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #916819 13th Aug 2021 8:32pm
G4R1
They screw into existing holes. No drilling is required. 3.0L MHVE D200 S Pangea Green+Black Pack
Post #916831 13th Aug 2021 9:14pm
Hairy Dan
Bow down Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #916851 13th Aug 2021 11:00pm
JackW
United States 1998 Defender 90 300 Tdi SW Coniston Green
Very clever - looks like you just swapped the stock mounting brackets left for right as well. very clean installation - I'm copying this one since the sincerest form of flattery is imitation.
Post #917016 15th Aug 2021 3:47am
pjb
Interesting how some mount the table with the flat edge as the work surface when down & others mount it the other way up so the table has an slight upstand 😊 2020 P300 HSE
Post #917017 15th Aug 2021 5:00am
pjb
Ps latest locking mechanism is excellent- up grading mine to those 👍 2020 P300 HSE
Post #917018 15th Aug 2021 5:01am
Page 3 of 4 <1234>
