Home > Modifications & Maintenance (L663) > Fold down table. |
Fair enough Darren
10th Jan 2021 10:41am |
SN Member Since: 29 Jun 2007 Location: SK6 Posts: 729 |
Nice. I expect the offset is because the existing bolts in the door line up exactly with the back frame sides - I'd be tempted to do something similar to the OP's solution with angle brackets to get the centring. Thanks for the photos though! Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history) |
10th Jan 2021 4:52pm |
Oldmowgli Member Since: 31 Oct 2020 Location: Sunny South East Queensland Posts: 34 |
Thanks to both OP and PaulMark for the info, these fold down tables look like a great addition, and not expensive. I've just ordered one too.
Cheers Oldmowgli |
12th Jan 2021 9:32am |
Much as I like the extendable one for the extra space, I notice that it blocks access to the bin in the tailgate door unlike the (cheaper) one described by the OP Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
12th Jan 2021 9:35am |
OP ~ top effort. That looks very nice and maintaining access to original bins/cubby a definite plus.
Is the cable in the tethers just new or actually a little inflexible? |
18th Jan 2021 7:03am |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1097 |
Easily fixed with a hacksaw though. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
18th Jan 2021 7:12am |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
Did it, too.
For the door panel replacement bolts 6x30mm is enough. 35mm not necessary. My fold down table came a wee bit narrow, I had to add 5mm spacers. No big deal. Did add them at the inward side so they are not obviously visible. Thanks to G4R1 for this great mod idea. Click image to enlarge |
24th Feb 2021 2:51pm |
SCP73 Member Since: 27 Feb 2021 Location: Essex Posts: 16 |
Looks really good - and using existing placements was an absolute gem. When the 110 arrives, I will certainly be investing in this well thought out solution. |
27th Feb 2021 7:44pm |
Right seen enough, I have ordered the requisite bits, I will probably 3d print the spacers when fitting on mine. Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
27th Feb 2021 8:58pm |
trinner Member Since: 13 Oct 2020 Location: San Diego Posts: 8 |
I like that I didn't have to alter the door at all and used the same trim mounting locations.
I also made a little shelf for stuff to fit underneath, I've got 2 medium sized dogs that have to go back there. Thanks for the post! Click image to enlarge Click image to enlarge Click image to enlarge |
3rd Mar 2021 6:43pm |
Last of my bits turned up today - the Bosmutus Tailgate Table itself
Click image to enlarge Approximately three weeks in front of the car And SWMBO has just accused me of "I'm sure you're trying to build another car in the gragae before your new one has even arrived!" On balance I might actually have more Jeep than Defender bits in my garage right now! But I have a cunning plan... Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history) |
10th Mar 2021 2:45pm |
Scrumps Member Since: 24 Feb 2021 Location: Somerset Posts: 108 |
Hi,
What vintage are the Jeep bits? I have a ‘44 MB😀👍 Scrumps 90 D250 HSE Tasman Blue 24MY L461 RRS Verasine Blue 05 TD5 90 CSW Cairns Blue 1967 MGB BRG 1944 Willy’s MB OD green 1942 Willy’s MB OD green |
10th Mar 2021 3:07pm |
Amazon item description says "Jeep Wrangler TJ JK JKU 1996-2017 2/4 Door Rubicon Sahara sport" Steve N | 21MY Defender | 08MY Discovery 3 (history) | 06MY Discovery 3 (ancient history)
10th Mar 2021 3:11pm |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
I suspect those bits in the box are all the Jeep parts.
