![]() | Home > Modifications & Maintenance (L663) > Fold down table. |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1125 ![]() ![]() |
That’s very neat! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
A kit of parts - that you fitted or all made from scratch or?
G4R1 Member Since: 17 Aug 2020 Location: Barnet/Limassol Posts: 131 ![]() ![]() |
It basically a fold-down table for Jeep Wrangler
https://www.amazon.co.uk/dp/B07GWYMKTF/ref=dp_prsubs_1 And a set of brackets https://www.amazon.co.uk/gp/product/B08HWH...&psc=1 Also, you will need x4 M6 bolts about 30-35mm long. You also will need to drill x6 6mm holes (4 holes in the table bracket) and 2 holes in the 2 of the 4 angle brackets) 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
THANKS
denhams Member Since: 21 Jul 2020 Location: Las Vegas Posts: 26 ![]() ![]() |
Neat solution. Any rattles? Is it bolted or riveted through the panel? I can't make out from the photos. If it's bolted, how easy is it to remove the panel? 1981 Series III 88 Santana Especial 2020 Defender 110 SE 2023 Tesla Model 3 RWD |
SN Member Since: 30 Jun 2007 Location: SK6 Posts: 729 ![]() |
Like this... a lot.
![]() Many thanks! ![]() ![]() ![]() ![]() |
That's very neat - looks like it was always intended to be there. Darren
It is bolted using the existing holes/nuts, you don’t have to remove the panel. Just remove 4 bolts, 2 on each side of the panel and replace them with longer bolts (about 35mm long) to fix the angle brackets. 3.0L MHVE D200 S Pangea Green+Black Pack
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
Very nifty indeed.
I notice there are a few variants of these tailgate drop tables for Jeeps on Amazon.
This one caught my eye - no idea whether it fits as well as the one above - seems to be about 48mm longer (before the extender is pulled out) so not sure whether it would still fit on the existing Defender bolt holes as shown above (I think that one 600 wide)) https://www.amazon.co.uk/Front-Runner-Drop...K9QZNFGCWQ ![]() Click image to enlarge Steve N | 21MY Defender ![]() ![]() ![]() |
The distance between the existing screws is 660mm, I believe this version will work just fine, obviously will require 4 holes on the back of the table mount or a couple of angle brackets to match existing holes in the tailgate panel.
The version I installed the table itself is 600mm wide including the mounts is 628mm. 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
PaulMark Member Since: 29 May 2020 Location: Johannesburg Posts: 33 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge
Have this table fitted to mine. |
That's a very useful table with the pull out board underneath but I've got to ask - why is it off centre? Darren
That’s just how front runner installed it and it’s never bothered me enough to warrant drilling more holes in the table.
