Home > Td5 > Speedo transducer leaking
Matt110
Hi all.
This..... Leaks. A lot.
I've taken the sensor off it.
Are my worst fears true in that it tightens from the other side inside the housing that the hand brake drum bolts to?
If so how do I get to it? I can't find anything on what's on the inside. I can feel it's loose just with fingers and you can see the oil moving so that's clearly the leak path.
All thought appreciated. Thanks.
Post #886551 19th Feb 2021 4:57pm
Mo Murphy
That's the speedo drive, get a wood chisel under the lip and prise the thimble out, remove the drive gear, replace O ring, replace.
Easy peasy.
50 Shades of Pennine Grey
Post #886565 19th Feb 2021 5:24pm
hank
Should come out that way
See page page 21 and 38 (pdf page numbers) here https://drive.google.com/file/d/1pxFpjzVmj...5wz4L/view > 110 XS Double Cab
Post #886567 19th Feb 2021 5:31pm
Matt110
Thanks Mo.
Consider yourself to have made my day! Rolling with laughter Thumbs Up
Post #886568 19th Feb 2021 5:31pm
Matt110
Thanks Hank, great diagram there much appreciated.
Post #886573 19th Feb 2021 5:40pm
Matt110
Thought I'd share the reason for my leak...
Super worn shaft on the internal oil shaft seal.
Photos below.
I'll order a new one so the shaft is new and ungrooved and won't leak I think and change the O ring also in the process.
You can just about make it out in the photos.
Thanks for the advice guys.
Post #886581 19th Feb 2021 6:08pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Think im going to need to do this on mine. Leaks a fair bit but havent had a chance to check it yet.
Post #886602 19th Feb 2021 7:46pm
Matt110
I'm currently trying to figure out which bits are serviced and which aren't.
This is a close up of the shaft so I need a new speed sense shaft (pitted) and a new oil seal, them a new O-ring the right size to refit it all.
Post #886610 19th Feb 2021 8:03pm
dorsetsmith
Post #886693 20th Feb 2021 9:38am
Mo Murphy
I'd change the seal and o ring, Matt, and see how you get on.
Post #886710 20th Feb 2021 10:20am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I agree just change the seals and put it back in. Also check your breather there should be no pressure in the t-case, and a new seal should work just fine. Thumbs Up good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #886765 20th Feb 2021 3:12pm
LandymanStefan
Matt did you get round to fixing this? If so which parts did you buy. It’d be good if I can order the bits before taking mine apart.
Had a little look at my situation yesterday...
Post #891296 14th Mar 2021 10:06am
Matt110
Yeah looks identical to ours.
I ordered all the bits and fitted but don't yet know if it's fixed as our MOT isn't booked till the end of the week. But it's now all new so it should do.
I fitted a new oil seal, a new O-ring, and due to my Speedo shaft being pitted where the seal runs, a new Speedo gear and shaft. My logic was that the oil seal would have a hard time sealing against a pitted shaft.
Wasn't expensive.
Talk to Dan at duckworths and tell him you want the same Speedo bits he did for me and he should be able to post straight out.
This is the list...
And it should represent the following...
Speedo gear. CHECK YOURS IS BLUE BEFORE ORDERING! (there are both blue and green and a few other colours. The LR record for what was in ours was wrong, don't go by dealer record. Whip it out, check colour of yours, then order. Mine was blue.
The oil seal for the shaft...
And the O-ring for the main housing. Haven't got a decent shot of that.
Do check with Dan before you order. I'm 99%sure that's the PN list but I also ordered half a dozen other things on the same invoice so there's risk I've got the wrong PNs selected.
Post #891304 14th Mar 2021 10:35am
Matt110
..actually the O-ring is shown in the first image on the housing outer..
Post #891308 14th Mar 2021 10:41am
LandymanStefan
Great thanks. Best to take it apart before then to check the gear condition/colour. I would imagine my gear has the same wear as yours if it’s leaking... we’ll see.
Post #891334 14th Mar 2021 12:55pm
