![]() | Home > Td5 > Speedo transducer leaking |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
Yep. I think combination of the gear shaft and seal hardening and wear on mine.
Aaaaah that's no good Stefan, you can't put your old bits on a TV Times, you have to take shots of it on the Haynes manual or a LR publication! (Mug of tea optional)
![]() Glad you got it sorted. Ours was definitely shaft plus seal. We've changed seal before and not solved it. Changed shaft and it's not leaked since. ![]() |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 ![]() ![]() ![]() |
Called the local stealership today and they only do the oil seals in packs of 5 and o rings in packs of 10 and at stealership prices there’s no way I’m doing that.
Been trying to get through to duck worth’s but it seems impossible. Who did you contact there? Have you got an email address? Thanks |
http://minispares.com/product/classic/AAU2304.aspx
571665 o ring |
Thanks Dorset, managed to get through to duckworths in the end, apparently had computer issues today hence not being able to get through.
They’re willing to split packets and sell single items 👍 |
Mini Landie Member Since: 23 Sep 2015 Location: Basingstoke Massiff Posts: 159 ![]() ![]() ![]() |
How the
![]() ![]() ![]() Edit: Oh, child of an unmarried couple is filtered. ![]() |
A small screwdriver was sufficient for me. Someone else mentioned using a wood chisel.
