Home > Expedition & Overland > Henri the 110 goes pop top! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17507 |
When you say cover, do you mean the plastic thing in the photo on the previous page?
Click image to enlarge I've never been sure what the purpose of this thing is (and the corresponding one on the other side), nor even which vehicles have them. I suspect that they are intended as insulation or sound-proofing and maybe were fitted to XS models only, certainly my County-spec DCPU never had them. They seem pointless to me, and presumably trap mud and damp. I'd be fascinated to learn if there is any benefit to having them. |
10th Feb 2021 9:00am |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Looking really good Tim!
What is the working capacity of the water tank ? I’ll be picking your brains later for fitting tips! (just have to save up first!) Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
10th Feb 2021 10:51am |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 |
Most people I know with them remove them as they fill up with dirt & promote rot if used a lot off road. |
10th Feb 2021 5:14pm |
Hi Gary, both fuel tanks for us giving us 850 mile range. The sill tank is 56L, we went for a canister water system as it’s easier to clean & more flexible. |
10th Feb 2021 5:17pm |
Main tank fitted, changed the rear lines & let it bleed itself. Started first turn..
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
12th Feb 2021 7:37pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
Yes this is a 90 tank, I cut the top of the tank and welded in the two boxes so that it would go directly underneath the battery box as there are two boxes sticking out underneath the battery box. I also made a ‘Y’ piece at the fuel filler to fill both tanks (main original and aux under drivers side) so I didn’t have to cut another fuel filler Click image to enlarge Click image to enlarge I use the tank under the battery box as water and I fill from the rear quarter Click image to enlarge |
14th Feb 2021 5:52pm |
Nice work, wanted separate filling points so it’s a separate system incase we get contaminated fuel. Empty the main & then pump the sill tank into the main.
14th Feb 2021 6:43pm |
Finally! Zero off set wheels have arrived.
4th Mar 2021 5:26pm |
4th Mar 2021 5:28pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10830 |
They are looking good on Henri Clayton.
5th Mar 2021 8:46pm |
Big day today with the suspension turning up.
10th Mar 2021 9:35pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Looking good! James
10th Mar 2021 9:50pm |
Yesterday was a full on day...
14th Mar 2021 3:37pm |
Before & after....
14th Mar 2021 3:39pm |
