Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD
Page 1 of 19 123 ... 171819>
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
Has anyone had this message on the new 3.0L 6 cylinder Diesel engines with intelligent AWD?
Post #884562 10th Feb 2021 7:52pm
Simon Audi
Any ideas?
Did it clear on an ignition cycle?
Post #884564 10th Feb 2021 8:08pm
Digger2000
To be honest I didn’t think it was a problem at first just thought it was changing from 4wd to 2wd in different sections of the road where there wasn’t any snow. I will check tomorrow but I don’t fancy driving it about the roads they are like ice rink for a 2 tonne car on 2WD
Post #884566 10th Feb 2021 8:16pm
Retroanaconda
I’ve not seen that message on mine, I’d say it’s more likely to be an issue than normal functionality.
If you put the 4x4i screen on it shows you the locking diff status, as you drive they lock/unlock to varying degrees as dictated by conditions and the terrain response mode selected.
Post #884567 10th Feb 2021 8:29pm
Digger2000
Yes I have that on but the warning message came up over it and I didn’t want to delete the message until I had screenshot it so I could show LR assist. I’ll get onto them in the morning but my gut feeling it will be low battery as my car was stood in depot for 2 months prior to arrival at dealership.
Post #884568 10th Feb 2021 8:40pm
Digger2000
Land Assist are sending engineer first thing in the morning. I will update after they have been
Post #884574 10th Feb 2021 9:04pm
Digger2000
Land Rover Assist engineer has been out and run a diagnostic test which showed no faults. He thinks that when I changed the terrain from comfort to grass/gravel/snow mode that the system hasn’t recognised the change and brought up the warning. Recommended that I monitor the vehicle and ring back if it reoccurs but should be okay 🤞🏻
Post #884659 11th Feb 2021 8:46am
Simon Audi
Good news
Was the error still showing after an ignition cycle or did it clear on its own?
Post #884675 11th Feb 2021 9:24am
Digger2000
No warnings on start of ignition this morning. Hopefully just a one off glitch.
Post #884678 11th Feb 2021 9:32am
Digger2000
The warning ⚠️ came back again today driving in comfort mode at 25mph over some pot holes. Booking the car into the dealership in the morning something isn’t right. I also had a strange scraping sound from the front passenger side break but I don’t think it is connected and seems to have gone now so could of been a stone or some grit.
Post #887209 22nd Feb 2021 11:43pm
rafman
Australia
Got my car 3 days ago and so far have had the message come up twice.
No idea what caused it, as I was just driving in normal mode on a regular road both times. Will hopefully get to LR service in the next few days to see if they have any further information. Certainly not very confidence inspiring.
Post #887228 23rd Feb 2021 7:26am
markb110
Anyone else remember the old Freelander 1 ‘fix’ of removing the rear prop shaft......?
Did the LR guy check that all the important bits were actually fitted in the first place..... Whistle
Post #887234 23rd Feb 2021 8:11am
DSL
Tell tale of important parts not there? Unusually high mpg and a smile from the owner at the pump. Whistle
Post #887238 23rd Feb 2021 8:25am
Digger2000
What engine model do you have?
Post #887242 23rd Feb 2021 8:42am
May be helpful - Brake Cyclical Noise / Judder 19” Brakes Only:
Post #887257 23rd Feb 2021 10:11am
