Home > Faults & Fixes (L663) > Intelligent AWD only drives in 2WD |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
Any ideas?
Did it clear on an ignition cycle? |
10th Feb 2021 8:08pm |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
To be honest I didn’t think it was a problem at first just thought it was changing from 4wd to 2wd in different sections of the road where there wasn’t any snow. I will check tomorrow but I don’t fancy driving it about the roads they are like ice rink for a 2 tonne car on 2WD
10th Feb 2021 8:16pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2683 |
I’ve not seen that message on mine, I’d say it’s more likely to be an issue than normal functionality.
If you put the 4x4i screen on it shows you the locking diff status, as you drive they lock/unlock to varying degrees as dictated by conditions and the terrain response mode selected. |
10th Feb 2021 8:29pm |
Yes I have that on but the warning message came up over it and I didn’t want to delete the message until I had screenshot it so I could show LR assist. I’ll get onto them in the morning but my gut feeling it will be low battery as my car was stood in depot for 2 months prior to arrival at dealership.
10th Feb 2021 8:40pm |
Land Assist are sending engineer first thing in the morning. I will update after they have been
10th Feb 2021 9:04pm |
Land Rover Assist engineer has been out and run a diagnostic test which showed no faults. He thinks that when I changed the terrain from comfort to grass/gravel/snow mode that the system hasn’t recognised the change and brought up the warning. Recommended that I monitor the vehicle and ring back if it reoccurs but should be okay 🤞🏻
11th Feb 2021 8:46am |
Good news
Was the error still showing after an ignition cycle or did it clear on its own? |
11th Feb 2021 9:24am |
No warnings on start of ignition this morning. Hopefully just a one off glitch.
11th Feb 2021 9:32am |
The warning ⚠️ came back again today driving in comfort mode at 25mph over some pot holes. Booking the car into the dealership in the morning something isn’t right. I also had a strange scraping sound from the front passenger side break but I don’t think it is connected and seems to have gone now so could of been a stone or some grit.
22nd Feb 2021 11:43pm |
rafman Member Since: 23 Feb 2021 Location: Perth Posts: 6 |
Got my car 3 days ago and so far have had the message come up twice.
No idea what caused it, as I was just driving in normal mode on a regular road both times. Will hopefully get to LR service in the next few days to see if they have any further information. Certainly not very confidence inspiring. |
23rd Feb 2021 7:26am |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 |
Anyone else remember the old Freelander 1 ‘fix’ of removing the rear prop shaft......?
Did the LR guy check that all the important bits were actually fitted in the first place..... |
23rd Feb 2021 8:11am |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 |
Tell tale of important parts not there? Unusually high mpg and a smile from the owner at the pump.
23rd Feb 2021 8:25am |
What engine model do you have? |
23rd Feb 2021 8:42am |
May be helpful - Brake Cyclical Noise / Judder 19” Brakes Only: Click image to enlarge Click image to enlarge |
23rd Feb 2021 10:11am |
