Home > Maintenance & Modifications > Neoprene window block seals? |
jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 168 |
I’ve cut the 4 seals from 2mm rubber sheet using the card seals as a template, worked perfectly.
3rd Feb 2021 6:49pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3677 |
Thanks. I’ve got some 2mm rubber sheet as well so will give that a shot.
3rd Feb 2021 7:28pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2009 |
EPDM flat roofing rubber offcuts work a treat. If you are after some just ask at your local roofing or building supplies.
3rd Feb 2021 8:42pm |
I've also used rubber sheet to make gaskets. I used 1mm thick though as I'd tried 2mm on my previous 90 and whilst they worked, they did bulge out around the edges quite a bit.
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
3rd Feb 2021 9:19pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
I used 1mm rubber sheet. Rgds. Chris |
3rd Feb 2021 9:31pm |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 162 |
Got any left over? Mine is collecting water now - it must be the only thing on it I haven't covered in silicone.
5th Feb 2021 4:48pm |
Think so pal - will give you some next time we catch up. Rgds. Chris |
5th Feb 2021 5:07pm |
Turns out the seals were fine. The idiot that installed the blocks forgot to tighten up the top bolt...
6th Feb 2021 11:27am |
