Home > Maintenance & Modifications > Neoprene window block seals?
Co1
Mine are leaking like sieves. I have some 1mm adhesive backed neoprene. Will that make a suitable seal instead?
Col
Post #882984 3rd Feb 2021 6:38pm
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I’ve cut the 4 seals from 2mm rubber sheet using the card seals as a template, worked perfectly.
Post #882992 3rd Feb 2021 6:49pm
Co1
Thanks. I’ve got some 2mm rubber sheet as well so will give that a shot.
Post #883004 3rd Feb 2021 7:28pm
Ianh
EPDM flat roofing rubber offcuts work a treat. If you are after some just ask at your local roofing or building supplies.
Post #883019 3rd Feb 2021 8:42pm
I've also used rubber sheet to make gaskets. I used 1mm thick though as I'd tried 2mm on my previous 90 and whilst they worked, they did bulge out around the edges quite a bit.
 Darren
Post #883027 3rd Feb 2021 9:19pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
I used 1mm rubber sheet. Rgds.
Chris
Post #883031 3rd Feb 2021 9:31pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Got any left over? Mine is collecting water now - it must be the only thing on it I haven't covered in silicone.
Post #883419 5th Feb 2021 4:48pm
Pacha
Think so pal - will give you some next time we catch up. Rgds.
Chris
Post #883426 5th Feb 2021 5:07pm
Co1
Turns out the seals were fine. The idiot that installed the blocks forgot to tighten up the top bolt... Embarassed
Post #883557 6th Feb 2021 11:27am
