Home > Off Topic > New Work Shop build
Page 4 of 7 <1234567>
L110CDL
That is a big update Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #880905 25th Jan 2021 10:30pm
Co1
That’s a bloody big workshop! Green with envy!!
Post #880917 26th Jan 2021 6:10am
sako243
Stacey007 wrote:
So you can almost see how far the levels are out...
There is an awful lot of Earth to move.... my lad on the digger
So we started moving the earth
My next job to move this lot.... I hand-balled this in the afternoon.....aarrgghhh
the motorized wheelbarrow helped but still hard to unload... it was manual pull it up...
I need more but its a start
Our Garden now... Rolling with laughter good job the Mrs is ok with this.. Thumbs Up
I am so glad I've got the ability to get slightly bigger machines in to my place Whistle
And testing out some welding on some DIY forks for my machine makes moving around bags so much easier Laughing
 Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #880982 26th Jan 2021 10:26am
Stacey007
^ that would be so much easier Smile
But then I don't need any Gym membership (even if I could) as I've moved I don't know how many tonnes of crush, sleepers, posts, wood,metal and blocks etc I've lost count. I'm far from over either, I know all the local building supply truck drivers Smile
Smile
Still I plod on and I can see some progress so all good Thumbs Up
Post #881141 26th Jan 2021 6:58pm
sako243
I've done my share in the past so you have my sympathies but it is rewarding.
Mind you there's a difference in scale here - I'm not sure I'd want to hand ball 150 tonnes of shale to make the driveway and pack it down. Plus the extra 100 tonnes that was stockpiled for backfilling Laughing Ed
Post #881186 26th Jan 2021 9:30pm
Stacey007
Weather has changed again and its very wet, I've been digging holes ready for the steel beams, which is fun...anyway I've plodded on and hopefully they are almost ready.
The beams arrived today so after work I had to see if they at least fit and 'look' right.
So now more aggregate, cement, sand on order ready to concrete in. Not to mention 25 or so sleepers to slide in.
Levels and everything need checking but if gives you the idea... the Soil raised up is much higher than the finish level so will be spread all over the garden.
Post #882731 2nd Feb 2021 6:09pm
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Looking good - I had a very similar problem to solve as you, the old garage just had the earth piled up against it! I used Gabions filled with local Cotswold stone, took me forever to get the right size / shape stones to fit each basket.
Post #882732 2nd Feb 2021 6:14pm
Stacey007
^ That looks well worth the effort now its done.
Nice job. Thumbs Up
I've just been out for more sand and cement... May have ago at concreting them in tomorrow.
Post #882956 3rd Feb 2021 4:44pm
Stacey007
Retaining wall with Steal beams as supports. Almost complete......
Post #886404 18th Feb 2021 8:43pm
Stacey007
Post #886407 18th Feb 2021 9:18pm
Make sure to put a membrane (Geotex or similar) behind that wall or you'll find the soil being washed out between the joints. Darren
Post #886418 18th Feb 2021 11:10pm
Stacey007
I've sorted a membrane behind the wall Smile and underneath where each of the first beam sits. Thumbs Up
Then started digging out where the ramp will go up into the garden.. (the sides)
test fit to see the levels...
just ordered some long 12mm wood drills to drill right through this lot and use rebar to hold them in place, with garden each side they are not going anywhere....
So also finished the block work for the surround.
Then took on the forth road bridge of jobs... to smarten up the fence along side... Current panels look like this... with slight gaps between.
300m worth of wood later we have started cladding 'our' side after painting the panel behind..
Worth the effort as fence now look new... trouble is it just keeps going... think around 17 panels and that doesn't include the 'normal panels to the left which I need to do) however Mrs is happy and too be fair a bit of a change from digging and moving stuff for me.
So also working out when we spread the soil back over the garden the whole garden will be levelled out better but also be raised up...
So just test fitting where I will sort some edging out...
I've been kept busy after work and the weekends that's for sure, its starting to come together now and looking more (in my eyes) done. Hopefully not too much longer working in wet , muddy soil / mud / clay.
Still need to dig out for the drains... and many other jobs but.... its all good.
Post #888985 4th Mar 2021 11:27am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Looks really impressive. Thumbs Up
Post #889004 4th Mar 2021 12:24pm
JOW240725
That looks a big job!! but impressive! Thumbs Up
If it were me I'd want to paint the steelwork with a black bitumastic paint (or at least the unfinished steel channel) for protection. James
Instagram @suffolk_rovers
Post #889008 4th Mar 2021 12:49pm
Stacey007
^ The job has grown...
typically, you do one thing it has a knock on affect to others,
The steel that is sunk in the ground has a metal preserver on it, the bit sticking up I will probably paint with something more suited if on show. However I think in the bigger picture I will box the steels in... Thumbs Up
Pretty sure either way the wooden sleepers will rot before the steels. They will have to look 'nice' to get signed off from the boss. Thumbs Up
The fence wasn't even on the list of things to do but I might as well do now and make it neat for the 'new build' trouble is even on its own its a big job Smile
Thanks for feedback and comments, I'm enjoying it and its quite satisfying knowing I've done it... I cannot imagine the labour cost so far if I paid for all this work.
Post #889011 4th Mar 2021 12:57pm
