Home > Off Topic > New Work Shop build |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3757 |
So after emptying the old garage... Managed to find someone who wanted it...
so..... Click image to enlarge Click image to enlarge Click image to enlarge gone.... So now I need to make the base, wider and much longer, the levels are all to pot with the current slam raising up towards the garden. |
23rd Sep 2020 6:18pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3679 |
Settling in to watch this one! I do love a good workshop build.
23rd Sep 2020 6:24pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2656 |
Absolutely. Timber structure or masonry?
23rd Sep 2020 6:30pm |
Wooden,
Basically a huge shed only thicker and a tad bigger 6m wide by 12m long.... first peal back cut in the garden... Click image to enlarge Someone mentioned stumps.... I had the ones at the side removed with a stump grinder, but we had 3 at the back..... quite large !!! which we had to try and remove.... Click image to enlarge This gives you an idea of size, so removing 3 took quite a while !!! Click image to enlarge very handy that the guy I chose to help me do the digging drives a Landrover !!! Click image to enlarge |
23rd Sep 2020 6:40pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
I hope the new workshop is tall enough for your forthcoming car lift...? Every home should have one!
23rd Sep 2020 6:46pm |
^ it will not be.... due to planning I can only go up 4m.
With the span of the building the best we think we can get is around 800mm to 1000mm to jack up the car at one point in the garage. Using a stepped up joist / beam. to be honest that's better than what I had by 100% so will make getting under it easier anyway |
23rd Sep 2020 6:54pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1223 |
Do a Si Rafferty and bolt the garage to the lift so when you need it the shed goes up with the lift and still keeps you dry. Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
23rd Sep 2020 6:59pm |
Genius!!
23rd Sep 2020 8:00pm |
Tomcat 106 Member Since: 08 Jun 2015 Location: Essex, just. Posts: 125 |
....got to love a workshop self build project
Just sort of finished mine. All signed off....just a few internal jobs and I can move the toys back in Good luck! MY15.5 110XS CSW 1956 88" S1 2004 Tomcat 106 Comp safari |
23rd Sep 2020 8:14pm |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1428 |
No lift... is there opportunity to dig a pit before the new concrete is laid?
23rd Sep 2020 8:22pm |
I will get a small lift it just will not go up very high
Did think about a pit but the extra time, effort to build that. I've enough on at the moment. |
23rd Sep 2020 8:42pm |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 96 |
Is the side of the garage on the side of your boundary as it should be clear by 1M to fall under PD requirement?
23rd Sep 2020 8:56pm |
Is that a thing? |
24th Sep 2020 7:33am |
Well not so much a shed but Si did make a carport to enclose his lift next to the shed at home. In everyday use his vehicles could be parked undercover and if he wanted to work on them the carport went up with it so even if it rained he could stay dry underneath. Ed
24th Sep 2020 7:38am |
