Home > General & Technical (L663) > Pre heat option.. |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1092 |
This morning is a cold one (for Manchester UK) about -3 with a thick freezing fog.
Had to go out early so hit the remote start on the App. (No preheat option on mine) After 25 minutes it had defrosted the windscreen and rear screen, but not the side windows. I think it used the electric heaters to do this. The interior was barely mild! The engine is obviously so efficient it doesn’t quickly heat up. So, maybe ticking the times pre heat option with remote etc. is a good thing if your out regularly in sub zero. I had it on my D4 but hardly ever used it. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
15th Jan 2021 10:06am |
Yes I spotted that and set it to 22. Soon warmed up once driven. The heated wheel gets really warm! 2021 Defender 110 X-Dynamic HSE D300 MHEV
15th Jan 2021 12:13pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Too warm, same with the seat heaters, although when I put my back out last August just going out and sitting in the car with the seat on No3 setting gave great back pain relief! I have read that the seats that are heated and cooled aren’t quite as warm as the non-cooled ones for some reason. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
15th Jan 2021 2:19pm |
Yes I’d agree with that. My D4 seats certainly heated up quicker than the Defender. It still gets pretty warm and needs turning down though. 2021 Defender 110 X-Dynamic HSE D300 MHEV
15th Jan 2021 4:56pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3383 |
The new Defender seems a backwards step, I use the nice new app on the Velar but on my shiny new Defender that’s supposed to have 85 ECUs and the latest and greatest tech I will have to use the old app 24MY 90 D250 HSE, Tasman Blue
15th Jan 2021 7:39pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
I use the new app on all of ours, worked fine yesterday heating the car
Although realised the rear window was open 1mm since new Mike |
15th Jan 2021 8:32pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
What app are you using? This is what mine looks like when using the climate heat.
Hold the green button till it does its thing (about 5 seconds) then off it goes. Click image to enlarge 130's have feeling's as well you know |
15th Jan 2021 9:05pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2635 |
New app works fine for me.
15th Jan 2021 9:32pm |
I use the same app as you for my Velar but Tim is running the old app, seems a few others are as well, as the new one wouldn’t connect during set up. 24MY 90 D250 HSE, Tasman Blue |
15th Jan 2021 9:43pm |
Yes both work for me but I use the new one, runs a bit better Mike
15th Jan 2021 10:19pm |
New one refuses to recognise my user name/email/password - I spent a week with JLR iT trying to get the “new” one to work and when I tried the old one got logged on straight away. Gareth seems to have the same issue as do quite a few people on another forum. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
15th Jan 2021 10:24pm |
Chris_h Member Since: 06 Dec 2020 Location: England Posts: 18 |
Yes same for me, new app won’t login, so have to use old app.
16th Jan 2021 6:52am |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 |
No remote start option in Germany.
☹️ Saves the climate... |
16th Jan 2021 9:13am |
ChrisH install the old app, get it working then install the new app. 2021 Defender 110 X-Dynamic HSE D300 MHEV
16th Jan 2021 9:43am |
