Page 1299 of 1381 <123 ... 129812991300 ... 137913801381>
Mini Landie
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Failure 1) Tried to take the steering shaft off my 90 to replace it. Couldn't get good leverage off anything to pry with a pry bar or crowbar. Gave up. MOT test at a Landy specialist next week so might ask them to do it for me.
Failure 2) Finally made a start at replacing the driver side door mirror + arm, as for some reason it doesn't hold its tension anymore except for certain spots and is very easy to knock it from where I've got it resting. Opened the box I got a while ago as a replacement, only to find out I bought just the mirror and mirror housing. No arm included. Feck...
Failure 3) Finally made a start at looking into how to take the door card off, to replace all the door card clips/pins as the card is hanging loose. Couldn't work out how to undo the window winder. Gave up.
Success 1) Worked out why the door doesn't always shut and needs a good few attempts. Little round thing on the door striker on the pillar has broken so is now half the size. I need to push it towards the front of the car to get the door latch to shut the door properly. So now need a new striker assembly.
Success 2) There is none... Sad
Post #875654 1st Jan 2021 2:25pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Oh dear , I sympathise completely .
I can offer you some help with two of those .
1. To remove the steering arm , coat liberally in oil , undo bolts at both ends and withdraw bolts completely as the bolts go through small indents to prevent it falling off ! Try tapping with a piece of wood down from the bulkhead end onto the steering arm, also try and lever open the piece around the spline with a chunky screwdriver .
Failing the above and on the basis you’ve got the steering box end off , attach a ratchet strap to the arm from underneath the chassis and ratchet it up against something on the exterior of the vehicle (another vehicle) . Meanwhile tap away and it should pop loose !
2. The window winder is held in place with a wire circlip. Push the door card in a bit and shine a torch in behind the handle and you should be able to see it ! Pop it off with a screwdriver whilst turning the window mechanism against it . Easy when you know how . https://www.instagram.com/hustynminepark/
Post #875667 1st Jan 2021 3:54pm
Mini Landie
Are these the bolts that hold the clamps over the splines tight? If so, I managed to get those off relatively easy enough and the bulkhead-end was wiggling nicely. It was just that middle-lower section that I couldn't get to slide so couldn't get the top-end to slide down and off.
The play itself is from the steering box UJ but rather than faff around trying to get the UJ off the shaft, I figured I'd just get a new shaft assembly as they're not terribly expensive. Ya know... when I was taking those spline clamp bolts out, I said to myself "well this is pretty easy! Sometimes it's a nightmare getting easy access to bolts but with this, I can just turn the steering wheel!". Laughing
I'll try the door card thing again tomorrow, and also have a look at my loose rear door locking mechanism.
Post #875672 1st Jan 2021 4:10pm
Bluericky
Yes there are three bolts in total , you only need to remove the ones at each end clamp but you may find removing the third will help to take it apart .
You’ll need to knock the shaft down initially to pop it off the splines , then knock it from the other end to release it entirely .
If you have a puma you may find it easier to remove the airbox but that’s a bit of a faff . https://www.instagram.com/hustynminepark/
Post #875679 1st Jan 2021 4:26pm
Mini Landie
'tis a TD5.
The ballache issue I'm facing is that bloody brake servo and its piping being in the way of getting any leverage with a pry bar/crowbar.
Will try to find myself a bit of wood at work on Monday but with the MoT test next Thursday, I don't know if I fancy taking the chance of only being able to do some of the job with such a short timeframe.
My own fault. Should have tackled this sooner! 2003 90 TD5 Hardtop
Post #875692 1st Jan 2021 5:37pm
excossack
Finally got around to doing an oil change and filter swap on the 110.
Managed to snap the wires for the water in fuel filter sensor Sad
And then spotted the low level brake fluid warning sensor wires had both snapped. Sad 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #875932 2nd Jan 2021 7:29pm
excossack
Regards
John M0VAZ
Post #875933 2nd Jan 2021 7:29pm
MussEd
Scotland 2013 Defender 110 Puma 2.2 USW Baltic Blue
Finally got around to doing the air box mod this evening. For 1/2 an hour after starting I wished I hadn’t bothered. But some persistence and plastic butchery later and I got the static fan out. Only time will tell if it has the benefits others have experienced but I’m glad it’s done now.
Post #876503 5th Jan 2021 9:33pm
It is a bit of a tedious task isn’t it.
I remember when I did mine, not a big difference but worth doing.
Thumbs Up
Very Happy KEEP CALM AND Drill ON
Post #876521 5th Jan 2021 10:14pm
MussEd
All I've done in the Defender today is drive 5 miles after doing the Air Box Mod last night. What a difference! So chuffed I did it now. Annoying kangaroo judder has gone!
Post #876615 6th Jan 2021 12:27pm
That’s good. Thumbs Up Very Happy KEEP CALM AND Drill ON
Post #876704 6th Jan 2021 5:26pm
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
MOT
No advisories........ Very Happy
Post #879376 18th Jan 2021 7:48pm
CarMan
Treated my soft-top to a belated Christmas present in readiness for better weather and easing of lock-down
 Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #879589 19th Jan 2021 5:13pm
Juh@
Finland 2004 Defender 110 Td5 DCPU Orkney Grey
I cleaned 20cm snow from the top of the car. Now waiting for gettin bit warmer to do some installations... -3C, no carage!
Post #879815 20th Jan 2021 9:18pm
Adammacky
Fitted some cup holders for passengers in the back.
Post #879828 20th Jan 2021 10:16pm
