Home > My Defender > Dormobile Camper with a twist |
All good stuff except for the K&N filter. Some years ago, Pete Bell did some dyno tests of different filters and concluded that the OE paper one is the best of the bunch. Plus, the oil on K&N's, IGT's etc. have been known to gum up the MAF sensor. Darren
7th Dec 2020 10:37am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10817 |
I had a piper cross air filter years ago and you had to put oil on it, it was a load rubbish and the difference when i put a K & N filter on was so much better, BUT i have never put any oil on the K & N filter's and find them breath better than the paper one's that i have tried
This is my opinion and what i have personally found over the years with all my vehicle's 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
7th Dec 2020 9:24pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 |
That's interesting to know about the K&N
I'll keep monitoring it for now and next time round look at an original if it's no different |
7th Dec 2020 11:12pm |
Re jigged the pipe work now it’s fitted to the wingtop to stop it rubbing on the alternator bolt.
I drilled 2 holes in the arch plastic and run a jubilee clip through it to pull it tight to the wheel arch. Click image to enlarge With the exhaust bandage it stops the duct being crushed . Pic of the inside of the airbox with gubbins removed Click image to enlarge What to do with the hole in the bottom... |
9th Dec 2020 4:14pm |
I did finish the install of the tune and, to put it politely, it goes like off a stick now.
Air intake upgraded to 100mm intake pipe from the wingtop including airbox mod K&N filter BAS intercooler BAS silicone pipes BAS Tune EGR blank De cat and mid box removed From 1400RPM - 3000rpmish it pulls like a train The pipe de cat and mid box didn't make much difference but it does sound abit more fruity now The only downside is i tend to become heavier on the right foot Next job is timing chain replacement and i may drop the head off for valve cleaning as it's all full of from the EGR and crankcase breather. I have toyed with the turbo upgrade but it doesn't seem worth it other than maybe having further pull after 3200 rpm where mine starts to fall off the torque curve. It's not a racing toy |
6th Jan 2021 4:52pm |
Good outcome in the end after all the work carried out under the bonnet 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
6th Jan 2021 9:14pm |
We had a moment on Friday and went shopping at the local paint shop....
There’s still lots to do at the rear end but the roof will be coming off to get it into the workshop for that part Last edited by Badger110 on 21st Feb 2021 6:31pm. Edited 1 time in total |
21st Feb 2021 2:20pm |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 |
I could have sworn the doors I had off you were blue Paul? Loving the colour! what prompted the change? 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
21st Feb 2021 2:31pm |
Indeed they were!
I have gone through several styles of 2nd row doors and finally went with some new ones from sp4x4 which required painting. We were looking to change the colour from Buckingham Blue to something a little different and well, I think we’ve done that 😁 |
21st Feb 2021 9:59pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 749 |
Certainly have!
21st Feb 2021 10:31pm |
No problem spotting you now 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
22nd Feb 2021 9:05pm |
Finally back together.
Click image to enlarge Click image to enlarge Click image to enlarge I still have the roof and rear cross member to spray but it was too cold ( but sunny! ) today |
28th Feb 2021 5:37pm |
Taking shape there now with the new colour, what colour are you going to be doing the wheels or are having different rims 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
1st Mar 2021 9:19pm |
Still not sure on the wheels, wife wants Sawtooths, I want Blindos but I'm happy with the Wolf's, even if they sit inside the arch's
As for colour, I'll go for satin black..I think green will make it look tacky |
1st Mar 2021 10:00pm |
