Home > My Defender > Dormobile Camper with a twist
Page 1 of 5 12345>
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Here's my current project on the go.
Using a Utility SV 110 extended roof, i shoehorned a Dormobile roof from a 47 year Bedford CF Van onto it after many many nights figuring out how to make the larger dormobile roof fit and here are the results.
I also had the material remade so i could include a zip which allows me to open it up on plesant days Very Happy
The second row doors have also been replaced by older sliding window and antiburst handles to go with the military front set of doors.
With material open ( clamp not a permanent fixture )
I do have a build thread over on LR4x4 if you're interested Very Happy
Post #825383 14th Apr 2020 9:36pm
L110CDL
That is a great idea and you have managed to sort it out, looking good and i'm liking the extra front roof overhang, makes a good sun visor Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #825396 14th Apr 2020 9:58pm
Badger110
Cheers Smile
I like the overhang for many reasons, one is the extra storage and 2 is the ability to shade the interior better when we hit the hotter continents. Since these pics i have made struts down to the hinge blocks to support the extra weight when the top box has solar panel and stuff in it.
Have you used those van sides yet? I wasn't sure if this roof was outside when you picked them up or not, but it's been a long time in the making Very Happy
Post #825397 14th Apr 2020 10:09pm
wyvern
Looking very good Badger !
I wondered if you had gone ahead with the project and it looks great!
Looking forward to seeing what you have done inside now and hearing about your trips
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #825398 14th Apr 2020 10:17pm
Badger110
Thank you Wyvern, it has been a long time in the making with work getting in the way most of the time!
I have done a few more bits over the past few days
I had an old aluminium roof rack which was surplus. I cut it down, repainted it and rebuilt it to mount on the side of the truck;
and a picture of the struts supporting the roof. These have been trimmed abit to make them a little more subtle
Post #825403 14th Apr 2020 10:41pm
Procta
cracking camper Thumbs Up i would love a little project like this if i had a mrs to go away with on the weekends. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #825414 15th Apr 2020 12:53am
ZeDefender
Awesome job Bow down
I'd like to see the inside please... Tell someone you love them today because life is short.
Post #825420 15th Apr 2020 5:41am
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
What a great idea to reuse an old pop top, I really like what you’ve done and with the extended sun visor/ luggage carrier it will make a great overlander, please can we see pictures of the interior Thumbs Up cheers Paul Tash n Barney
Post #825425 15th Apr 2020 6:12am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Before you get a Mrs is EXACTLY the time to do a job like this, once you’re shackled up the amount of Landy time you have is limited.
Post #825429 15th Apr 2020 6:47am
Badger110
The interior is bare again as i stripped the old set up out which was designed for a standard 110 interior. Now we have standign room availible it's a new build!
The 110 extended roof came from this vehcile;
I collected it from Gloucester way, strapped to my 110 and brought it home.
I then made a frame for it to sit on so i could wheel it about in and out of the workshopp;
I made some timber braces to work on how the roof would lift and where the original rams would sit;
Once i had these i then made a 40mm box section surround which runs all the way around the hole in the roof and is braced down to the sides
I also stripped the grp roof, cleaned and insulated it
and then covered it and installed a strip light and 2 movable spots lights
I've reused the old headlining in the visor part and trimmed the front off to mask off above the sun visors and refitted the original light. I may replace that light with something else in the future.
The panels are made from ply and thin sheets of foam and material sourced from a charity shop and are fixed with screw caps ( the black spots ) as every panel is able to be removed for future proofing like checking for leaks, condensation, access to wiring etc.
You will find that i recycle or upcycle as much as possible, in my old line of work i always had plenty of building materials to hand, other than that i reuse whatever i can.
I'll be adding more pics as i go along Very Happy
Post #825538 15th Apr 2020 11:59am
JOW240725
Great work! James
Instagram @suffolk_rovers
Post #825587 15th Apr 2020 4:00pm
ZeDefender
Thumbs Up Tell someone you love them today because life is short.
Post #825590 15th Apr 2020 4:23pm
L110CDL
Badger110 wrote:
Cheers Smile
I think the roof was outside but i'm not 100% sure as it was a while back Thumbs Up
As for the sides they are in my store with the other bits that i'm collecting for my 90 project, when i can get time to make a start on it with one thing and another delaying me Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #825621 15th Apr 2020 7:17pm
VVS210
Is that the roof from the Bedford you had off the chap who thought you were going to restore it & give it a new lease of life Whistle
Very impressive work Thumbs Up
Post #825645 15th Apr 2020 9:00pm
Sulisuli
Great build thread Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #825647 15th Apr 2020 9:03pm
Page 1 of 5 12345>
