![]() | Home > My Defender > Dormobile Camper with a twist |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
The extended roof was fitted to western power vehicles in the south west, I believe for fitting the long reach "hotstick" insulated tools for high voltage work. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
That's good to know, i shall be placing that knowledge of hotsticking in any future blurb about the build ![]() |
Fitted the snatch bull bar today, now to source some more friendly tyres.
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Have to say, it's looking the "mutts"
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1232 ![]() ![]() |
like that
![]() 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2188 ![]() ![]() ![]() |
Just what yu need to deal with the current 'end of days' scenario.......
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10872 ![]() ![]() |
It does look good
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Thank you all
![]() Had a not so good conversation with he insurance people who weren’t happy that there isn’t an engineers report on the roof even though dormobile sell the roof as a ‘kit ‘ but mine isn’t designed for a land rover. I explained it has a 40mm box section framework bolted to the roof, but to an insurance person, that means nothing. I’m now in a quandary as to whether I can keep the roof or get it signed off by a relevant body. So I’ve been advised not to drive it until they can get someone to come take a look and in the meantime I either get documents from Dormobile stating the build is correct or contact DoT regarding an IVA. In the meantime I’m working on the interior as that’ll be the same regardless... every cloud and all that ![]() |
Can you not find an engineer that can write a suitable report for you? It may cost a few hundred £ but it's got to be worth it given all the work you've put into it. Either that or find a different insurer. Darren
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
Brilliant that they're worried about the roof but not the spare wheel and bull bar!
Bull bar is a factory produced item.
For the military, yes, but they were fine with that. Insurance company have been great in the past, but they’ve only got 1 in the office and she’s not sure. It’ll sort itself out one way or another, even if I do have to get a report. Stuck at home for another 8 weeks, it’s not being driven |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2118 ![]() ![]() ![]() |
When we had our first dormobile inner conversion on a TD5, it came with an engineer report from an independent through Dormobile, then when we moved all the kit into our pervious defender (2.4 TDCI) we had to have a report for the fittings which was supplied by our local independent garage at a very reasonable cost.
We had the new inners then the roof fitted in Germany and they supplied an engineers report for both these modifications as per german auto requirements. So its something that is probably expected for modifications to the vehicle structure and peace of mind. Fingers crossed for you to get it sorted ok. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
I can see their point of view and to be honest, for my own peace of mind i'd like someone to look at the extra support i've put in and say yes, you did it correctly ( which i know i did, but hey, we all like a nod from those in the know at times
![]() I'm speaking with them again at the end of the week, i'll keep you updated. |
I have a build thread on LR4x4, but i will keep you posted on here as well. It will be a copy/paste jobby
![]() Most trucks have a bench seat down one side in the rear and the cupboards, sink,cooker down the other. In a van this works as it utilises the most amount of space, however it's terribly boring and if you do sit down for something to eat, you're staring at a wall of cupboards ![]() I got my thinking cap on and came up with a few ideas. First one was to swap out the standard front seats for a bench seat. This would also make up part of the bed for the rear once it was folded down. If you fold the back rest down onto the base, you could create a seat base for the rear seats... Second idea was to replace the standard front seats with a swivel mechanism. It would've been a fair bit of work as i would need to re arrange the seat box itself, but not impossible. The downside to this was the height issue. The front seats are low on the seat box and turned 180 degree's meant you would have to sit with your legs out in front of you rather than like a proper seat. Those 2 ideas were ditched. The first because i came up with a different idea for a bed in the back and the second idea because the seating position wouldn't have been comfortable. The third option is the one i went with. Firstly i had to do a little job to the front seats. They lean back and lock and will lean to an upright position to lock but won't lean forwards and lock. The reason is there is a small pin on the seat base which moves out of alignment after the upright position. It allows the seat to ' flip ' forward. The design, i think, is due to having rear seats and no rear door in some 90 models. You gain access by flipping the front seat forward. I could be wrong. Anyway i needed to remedy this. Whipping out the welder, it was a case of welding a spot on the seat base which allowed the pin to stay in a position so you could lock the seat using the standard grooves. So i went from a maximum position of this; ![]() Click image to enlarge to be able to lock it in this position; ![]() Click image to enlarge by putting a spot weld here it allows the pin to move further along ( see arrow ); ![]() Click image to enlarge Once that was done to both seats, i was able to make up a seat box in the rear which had movable tops to allow it to be in ' travel ' mode and in ' stopped ' mode. The seat box also had a sub fitted into cause i like loud music when i drive ![]() For the rear seat, i needed a back rest, i went with something simple. I took a dog pen panel; ![]() Click image to enlarge and cut it down by 6 inchs and re welded it to produce 2 panels which were then hinged at the bottom and fitted to the truck floor just behind the front seats; ![]() Click image to enlarge together look like this; ![]() Click image to enlarge ![]() Click image to enlarge Both panels are independant of each other and can be moved when each of the 2 front seats are forward or back. ![]() Click image to enlarge In the below picture you can see the difference in the seat base's being in ' travel ' mode ( behind the driver ) and ' stopped ' ) mode behind the passenger. ![]() Click image to enlarge Overall view of the seating in the rear of the truck looking in from the rear. When we stop, the front seats get pulled forward, flipped and locked in position, seat base moved back and voila, we have a seat for the rear. Access is via the side doors and it's fairly easy to get in and out. The width of the seating is fully across the truck at 1400 and these cushions will double up as a bed base, which i'll cover later on in the build. ![]() Click image to enlarge ![]() Click image to enlarge Lastly it's a picture of dog number 1 helping out again.... ![]() Click image to enlarge ...it's a hard life being a Basset Hound ![]() Click image to enlarge |
