Home > My Defender > a 130 itch |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
You've done a great job with that 130 James - I'm really impressed with the thought and hard work you've put into it. I've always had a soft spot for 130s since working on them in the 90s. Pretty much the perfect Defender IMHO
2nd Oct 2020 7:34am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
130 working well last few days, slight water leak through bulkhead needs to be sorted. Getting around 25mpg with mixed use including towing around 1.5t avg.
Click image to enlarge Click image to enlarge Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Oct 2020 4:24pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10854 |
Your 130 makes the trailer look very small Clayton.
7th Oct 2020 7:46pm |
It is only a gd85! Cheers
13th Oct 2020 8:17pm |
First day out driving guns around on the local shoot yesterday, they are all loving the rear legroom!
15th Oct 2020 7:01am |
Replacement gbox, ashcroft intermediate upgrade shaft and 1.3 ratio lt230 arriving soon! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 9th Nov 2020 8:19pm. Edited 1 time in total |
18th Oct 2020 3:31pm |
Click image to enlarge Click image to enlarge Thank you Ashcrofts. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
19th Oct 2020 3:32pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1632 |
more work but worth it.
cant wait to have a drive in it |
19th Oct 2020 8:21pm |
There's a queue at the moment. On the last shoot day where I provided transport, guns immediately booked inntheir seat for next time. 1.3 box will help when towing . Its going to have to wait a little while bit busy.com at moment with it. Cheers
20th Oct 2020 6:49am |
Well this fell out today, just helping the spigot bearing put of the crank currently, then ready for refit.
9th Nov 2020 8:11pm |
Well this little gritter proved to be a rpita.
10th Nov 2020 7:37pm |
reconditioned gearbox and 1.3 ratio T box is in. despite the spigot bearing taking 2hrs to remove it was relatively straight forward. Clutch changed at the same time. Great to see whoever did the clutch last time didnt both refitting all the bell housing bolts (under the EGR cooler!)
only driven it 30miles or so, i need to sort the gearchange selection, hence my other post about the spacers here: https://www.defender2.net/forum/topic29132.html and this tech bulletin https://www.defender2.net/gallery/albums/u...uality.pdf ratio wise, really happy with it, 130 is part loaded, probably 200kg in the back plus the conversion weight, and with the 1.3 it drives like my 110 on a 1.2 box. very pleased with the result. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
11th Nov 2020 7:37pm |
benspray Member Since: 30 Jul 2014 Location: Norfolk Posts: 164 |
Hi James
Any more details / pics of the rear tank guard / tow bar setup? I have what I believe is the same tank guard/detachable tow pack and recovery eye from my 110 (Southdown from memory?) that I was wanting to fit but wasn't sure of the best way to extend the mounting point for the tow ball to get it back to the original(ish) position. Thanks Ben |
13th Nov 2020 2:06pm |
Hi Ben, yes its a Southtown one. Are you talking about extending it for a 130 specific use? Do you have the original tow plate attachment? Cheers
13th Nov 2020 6:43pm |
