Home > Technical > Diagnostics for the Puma.
Page 5 of 5 <12345
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Faultmate MVS2 Extreme and Puma
Hi,
Anyone using the Faultmate MSV2 with a Puma 2.2?
I have problems in communication between the faultmate and the ECU.
Any help welcome.
VE version 1.33
And Defender SM133 version 1.29
Are these the latest?
Eddited...
Think I need VCI2 OBDII Diagnostic Lead (CAN Network) as I have one that was used for my previous car (Discovery 3)
A lot of money for a lead! Grrr.....
Post #597307 29th Jan 2017 2:46pm
NickMc
No sorry as I said I got shot of mine as I got sick of it sort of kind of working. Maybe try Bell Autos or RPI engineering (v8engines) as they used to do them and stock parts and cables, that's going back 6 years though.
Post #603222 20th Feb 2017 12:29am
annette
Costa Rica
In case somebody has the same problem with Faultmates and their cables.
I bought some 15 pin serial plugs in Panamá, filed them down to fit, soldered nice flexible cables from the Electricity board Embarassed on the pins and dipped it all in Poxypol
So I have a new main cable, a new Can bus one and a new direct CPU for the BECMs
My old toughbook now works fine through a whole remap session.
Another solution is by Bearmach's cables for the non pro Hawkeye and use a gender changer.
Who wants to have a cable sent round the world Smile Fixing Land Rovers in rural Guanacaste
Post #732316 1st Oct 2018 8:51pm
NickMc
Or just buy and Autologic that actually works Laughing
Post #788621 25th Aug 2019 11:07pm
Low Boxer
United States 1990 Defender 90 200 Tdi SW Nato Green
Thank you, lots of good information here. I've been though the Autologics and Rvacoms. Have a Hawkeye around as a loaner, to friends, but pretty much only use SDD now, its expensive and not the cure-all one would expect. So I'm always looking for better. I like the idea of compact and easy to use. Really appreciate all the effort you put into this.
Post #862960 21st Oct 2020 11:25pm
ForeignCartographer
United Kingdom 2013 Defender 90 Puma 2.2 SW Arles Blue
Thank you Brian for the effort you put into this post/thread.
Are these recommendations still valid in 2022?
Ben
Post #941865 9th Feb 2022 9:54pm
Brian hasn't posted on here for some years, unfortunately. The technical stuff will still be perfectly relevant, though.
I haven't waded back through the entire thread but the only thing that stuck out from the original post is that it doesn't mention the Gap IID diagnostic tool, possibly because it came slightly later. It's an excellent bit of kit though, with great support. Darren
Post #941894 10th Feb 2022 8:37am
roche1800
Would anyone recommend a good all round diagnostic tool for 2.2 tdci and Td5 which connects to IOS.
It’s about time I bought one…
Post #1043352 20th Aug 2024 7:02pm
HardCharger
I use the GAP IIDTool - BT. Works with iOS and Android. if you have an iPhone, get a cheaper Android unit as well as there can be quirks with the iOS version that works with the Android version.
GAP is very helpful with their support so no complaints. No Better Friend, No Worse Enemy
Post #1043724 24th Aug 2024 3:20am
Page 5 of 5 <12345
