![]() | Home > Technical > Diagnostics for the Puma. |
Is it just me or are all the original photos now missing?
Probably been cleared out to make more room in his gallery. I had to do the same. ![]() Treat every day as if it is your last....one day you will be right!! |
It's a shame because a lot of historical information is lost. Still it's good to have a Spring Clean now and again to get rid of all the dross.
but pretty useless when it's a sticky thread
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 ![]() ![]() ![]() |
Did Lorryman take the whole thing with him when he left ... ? Noticed the first post now says "Deleted ..."
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
@timbar: Why Lorryman leave this forum ?
He hasn't left but just doesn't prolifically post as much as he once did. His last post was in August. He is still 'available' to assist if you need help. Recently I made an enquiry to him via a 'pm' and the help, photos and assistance he sent back was invaluable. ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Cheers K9F. I managed to dig up an old copy of the post as well -- but will get in touch when I'm a bit more organised
Welcome.....
![]() He is a very helpful and amiable individual and I am sure he'll sort out whatever information you may need. ![]() Treat every day as if it is your last....one day you will be right!! |
Me too in the past I received a huge amount of help and information from Brian, his knowledge is invaluable!
2dae Member Since: 21 Sep 2013 Location: Maudsland Posts: 27 ![]() ![]() ![]() |
Rev counter goes to zero
Seems to be quite random Car runs in limp mode when fualt is active weird Anynideas out there |
Hi lorryman
Thanks for your ideas But i havent got a scanguage or the like. Hooked up Ive got a steinbeur chip in the fender that is all Wondering what else it might be I did pull the dash out and check plug on rear of instrument panel the wire seemed not to be in the small channel where i think it should sit maybe kinked a liitle i rerouted the loom put it all back together Will go for a drive in a few days see if it made a diiierance One further enquiry please Does it make any diferant if imobiliser is set to passive or active ?? Landy shop may have changed it last time it was at the docters I remember they said something about it My imoboliser button is and has always been difficult to use , sometimes you have to walk around the car pressing it repeatedly until it unlocks or locks the car It has always been a bitch to use |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 ![]() ![]() ![]() |
Looks like ive missed a good post
Hi john
Pete here Yep was fun indeed , fender has been running well for about 4 months now I did have a small issue last week driving home i lost power temp gauge went into red taco went off bAttery light on I pulled the dash out on the spot moved the wires goin into the rear of the instrment panel Placing them to the side of channel as i feel the may have had pressurre on them Put it back together and drove home all good been fine since Werid as Fernders have a mind of there own |
