Home > My Defender > My 110 Double Cab
Page 1 of 3 123>
Joel
United Kingdom 2002 Defender 110 Td5 DCPU Santorini Black
My 110 Double Cab
Hi all,
Newish here, but been a regular on other Landrover forums for a while. I have owned a 110 for a few years, but it failed an MOT and has basically sat in the garage for a couple of years. I always intended to get round to it but just don’t seem to have the time.
In the meantime I purchased a cheap disco td5 to tide me over, however as expected that failed the MOT.
Bit the bullet and bought a nice td5 double cab. Needs a few small things, but it’s been well maintained. Needs a bit of paint in a couple of areas, but it’s in good shape.
Post #862318 18th Oct 2020 8:01pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
That looks lovely
I like the look af a dcpu with nothing over the back 👍 My confidence has been writing cheques that my abilities can't cash for years.
Post #862320 18th Oct 2020 8:05pm
Grenadier
Very nice. Liking the full length rack. Welcome to the forum and welcome to the coolest sub-category on the forum, by far. The DCPU owners..... Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #862325 18th Oct 2020 8:18pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Welcome aboard - nice to see another black one - here's my Black LE from the same year:
Post #862331 18th Oct 2020 8:48pm
steve E
Wales
Very nice indeed
I’m loving mine too
Defender number seven and first DC
Post #862333 18th Oct 2020 9:01pm
seriesonenut
Joel, a bit OT but wondering if your front bumper has a set of drls and fog lamps? I'm looking for that combination to tidy up my usw front end. 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #862341 18th Oct 2020 10:18pm
90 Dreamer
looks same as my front bumper which is dual DRL's at either end..........
very neat
Post #862378 19th Oct 2020 8:57am
Joel
They are not DRL's, they are fog and full beams for some reason.
I'm not a fan of that bumper, or the KBX grille and surrounds if i am honest. I think its also got an aircon grille, but no aircon.
On my list of things to change at some point.
Joel
Post #862402 19th Oct 2020 11:09am
Roy5695
Double cabs are the best 😎
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #862487 19th Oct 2020 7:04pm
Joel
So, been working on various bits, and decided to investigate my Aircon. When I bought it the guy was adamant that it didn’t have factory air con. However it has the air con dash, compressor, drier and one air con pipe. I don’t think it has the aircon rad either.
Is there an easy way to tell if it was factory fitted, I am suspecting it was and at some point it’s broken and someone has had a go ant fixing it, left it half fixed. from what I can see, the only piece missing is something off the top of the aircon compressor and one of the pipes that go into the cab.
Is defender aircon actually any good? Debating if I should just remove the remaining bits or if I should buy the bits to make it work.
Post #874905 28th Dec 2020 11:05am
Matt110
On a puma system, at 40 degrees on a French motorway, in stationary traffic, when you've got a black one...... No. It's inadequate. But then I'm classing inadequate as "I'm not at the temperature I want to be", as I would on a modern car system. For the above motorway issue it's a tad unfair to expect any standard system with a UK specced condenser panel to keep pace with heat loss when you have an uninsulated black panelled greenhouse sat in that temperature.
In almost every other circumstance it's absolutely fine, certainly for all UK weather it's well worthwhile having.
The TD5 system is a tad noisy as on hot UK days I've found it has to run flat out the whole time to have any effect but again to my mind, the 90% the time when the system isn't outpaced by the weather again makes it worthwhile having. And our TD5 is also black. Makes a massive difference.
Just my thoughts.
Post #874907 28th Dec 2020 12:17pm
bankz5152
Very nice! Love the alloys
DCs do look the best!
 Instagram @defender_ventures
Empire Tuning - Agent
Post #874908 28th Dec 2020 12:49pm
Joel
That’s nice, assuming it’s yours, where did you get the bumper from?
Post #875003 29th Dec 2020 11:21am
bankz5152
Yeah its mine.
Devon 4x4 winch bumper & steering guard with a custom A bar
Post #875005 29th Dec 2020 11:41am
Grenadier
Bankz, what size hoops are you running? I’m on 265/65R18 (also on Bowlers) but will need new hoops in Spring and am thinking of upsizing to a 275/65R18. You look like you’ve got big ones. Shocked Whistle Very Happy Monsieur Le Grenadier
Post #875009 29th Dec 2020 12:03pm
Page 1 of 3 123>
