![]() | Home > My Defender > My 110 Double Cab |
Joel Member Since: 18 Oct 2020 Location: Rotherham Posts: 76 ![]() ![]() ![]() |
Hi all,
Newish here, but been a regular on other Landrover forums for a while. I have owned a 110 for a few years, but it failed an MOT and has basically sat in the garage for a couple of years. I always intended to get round to it but just don’t seem to have the time. In the meantime I purchased a cheap disco td5 to tide me over, however as expected that failed the MOT. Bit the bullet and bought a nice td5 double cab. Needs a few small things, but it’s been well maintained. Needs a bit of paint in a couple of areas, but it’s in good shape. ![]() Click image to enlarge ![]() Click image to enlarge |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Very nice. Liking the full length rack. Welcome to the forum and welcome to the coolest sub-category on the forum, by far. The DCPU owners.....
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
Welcome aboard - nice to see another black one - here's my Black LE from the same year:
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 ![]() ![]() |
Very nice indeed
I’m loving mine too Defender number seven and first DC ![]() Click image to enlarge |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1230 ![]() ![]() |
Joel, a bit OT but wondering if your front bumper has a set of drls and fog lamps? I'm looking for that combination to tidy up my usw front end. 1984 One-Ten CSW
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2185 ![]() ![]() ![]() |
looks same as my front bumper which is dual DRL's at either end..........
very neat |
They are not DRL's, they are fog and full beams for some reason. I'm not a fan of that bumper, or the KBX grille and surrounds if i am honest. I think its also got an aircon grille, but no aircon. On my list of things to change at some point. Joel |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Double cabs are the best 😎
![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
So, been working on various bits, and decided to investigate my Aircon. When I bought it the guy was adamant that it didn’t have factory air con. However it has the air con dash, compressor, drier and one air con pipe. I don’t think it has the aircon rad either.
Is there an easy way to tell if it was factory fitted, I am suspecting it was and at some point it’s broken and someone has had a go ant fixing it, left it half fixed. from what I can see, the only piece missing is something off the top of the aircon compressor and one of the pipes that go into the cab. Is defender aircon actually any good? Debating if I should just remove the remaining bits or if I should buy the bits to make it work. |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
On a puma system, at 40 degrees on a French motorway, in stationary traffic, when you've got a black one...... No. It's inadequate. But then I'm classing inadequate as "I'm not at the temperature I want to be", as I would on a modern car system. For the above motorway issue it's a tad unfair to expect any standard system with a UK specced condenser panel to keep pace with heat loss when you have an uninsulated black panelled greenhouse sat in that temperature.
In almost every other circumstance it's absolutely fine, certainly for all UK weather it's well worthwhile having. The TD5 system is a tad noisy as on hot UK days I've found it has to run flat out the whole time to have any effect but again to my mind, the 90% the time when the system isn't outpaced by the weather again makes it worthwhile having. And our TD5 is also black. Makes a massive difference. Just my thoughts. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Very nice! Love the alloys
DCs do look the best! ![]() Click image to enlarge Instagram @defender_ventures Empire Tuning - Agent |
That’s nice, assuming it’s yours, where did you get the bumper from?
Yeah its mine.
Devon 4x4 winch bumper & steering guard with a custom A bar ![]() Click image to enlarge Instagram @defender_ventures Empire Tuning - Agent |
Bankz, what size hoops are you running? I’m on 265/65R18 (also on Bowlers) but will need new hoops in Spring and am thinking of upsizing to a 275/65R18. You look like you’ve got big ones.
![]() ![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
