![]() | Home > My Defender > 1997 Ex-MOD 110 restoration + Alu Cab pop top |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 564 ![]() ![]() ![]() |
It came from Dara at Tuff-Trek, they happened to have a shipment due in in a few weeks after first contacting him with a couple of roofs still available so worked out nicely!
Don’t think you can buy direct, all EU sales come via Genesis in Germany I believe, the Alu-Cab EU importer. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
Decided to fit 130 helper springs to help with the constant load.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Got the bulkhead stripped and new footwells put in. Blast and paint next. ![]() Click image to enlarge ![]() Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
Thanks Clayton
![]() Bulkhead blasted, seam sealed, epoxy primer and raptor top coat... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Got the tyres on the rims now too, ![]() Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10859 ![]() ![]() |
wow it's starting to look like a land rover again
Haha! Yes indeed, definitely better when you start bolting bigger bits on
![]() 2014 Discovery 4 SE Tech Instagram @the110camper |
With that big bit on now, it can grow nicely now
Few more jobs done.
Fresh looking footwell... ![]() Click image to enlarge The battery box wasn’t beyond repair but decided to fit an ali YRM one instead... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Added sound deadening pads to the underside of the floor plates and seatbox before painting them... ![]() Click image to enlarge ![]() Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
New windscreen frame fitted, vent flaps on and engine bay pretty much complete.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Work starts on the rear tub now. Not in bad shape just needs bit of straightening to both side rear panels and a new offside corner capping. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
Very nice work done there db950
![]() One question, on your servo, the vacum pipe is on the bottom left hand side, is there any reason for this as mine is on the top right hand side ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Thank you
![]() Not sure about the servo pipe, I’ve replaced the master cylinder but not moved the servo so it’s in the same place it was. Maybe it has been replaced in the past and was put on 180 degrees out? 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html 2014 Discovery 4 SE Tech Instagram @the110camper |
Strange one that, always thought that the servo had to be put/fixed with the vacum pipe at the top right, thanks for the reply
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3690 ![]() ![]() ![]() |
Jeez-O! This things looking great. Top work 👍
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Great thread. Talent in abundance 1951 80" S1 2.0
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3475 ![]() ![]() ![]() |
Great build and attention to detail. I wish my build is going this fast too
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
