![]() | Home > My Defender > Td5 110 csw, Lowered, led's, Tints and Puma seats |
![]() ![]() ![]() This is a harder decision than I expected ![]() Ray ![]() My build thread http://www.defender2.net/forum/topic17615.html |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10874 ![]() ![]() |
100% with out Ray
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
Without gets my vote. Looks like your collection of A bars needs to go on ebay
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
I’m afraid I have to buck the trend. Cannot stand the over-sized spots, so they shouldn’t be there at all. Everything else you have on the front is ‘subtle’, whilst they’re not (colour and size) at all. Jarring. After that, both versions look good, but preference would be for ‘with’ A-bar. If you want spots, Lazers would be the biz.
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
I didn’t think the spots were oversized, they are just standard Landrover ones? I’m waiting for an air con pipe to arrive at the moment as when I went to get it gassed up one had a hole ![]() ![]() My build thread http://www.defender2.net/forum/topic17615.html |
I finally have working air con (just as the weather turns really cold
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2188 ![]() ![]() ![]() |
Not on the Truck, but I use mine a lot on frosty mornings as I fnd it clears the front screen far quicker than just the normal blower......
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
Nice one Ray
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Yeah I do the same in the wife’s defender, it clears the windows quite quickly. Hope mine works as efficiently ![]() My build thread http://www.defender2.net/forum/topic17615.html |
Thank you ![]() My build thread http://www.defender2.net/forum/topic17615.html |
That time again
![]() ![]() Click image to enlarge I found a small hole underneath so welded it up. No bigger than a five pence piece so not too bad. ![]() Click image to enlarge Por15 on which I’m hoping will protect it for many years to come. I couldn’t be bothered with filler to make it perfectly smooth this time so it is as 16 years has made it ![]() ![]() Click image to enlarge Some high build primer and flatting ![]() Click image to enlarge ![]() Click image to enlarge And top coats of Santorini black and lacquer should keep it tidier for a while. All the back of the crossmember was also stripped and por 15’ed just like the rest of the chassis. I still have a few sections and touch up bits to do which I hope will be done before bad weather hits. Ray My build thread http://www.defender2.net/forum/topic17615.html |
Decided I’m going to start swapping out bolt on chassis bits for galvanised ones.
![]() Click image to enlarge I’m just sorting a list of anti roll bar brackets brake shields etc and Need to find a galvanised tank cradle with the Inbuilt rear crossmember bolts next. Ray My build thread http://www.defender2.net/forum/topic17615.html |
Nice bit of crossmember work done there Ray
