Home > Puma (Tdci) > Turbo hose worn through - Not the usual.
Bluest
The hose from my turbo to the intercooler has worn through but not on the usual suspect the steering column. There are marks where it has contacted the steering column but it has actually pierced through on a rivet on the inner wheel arch that secures the foam blanket insulation stuff. Anyone else seen this? I’ll need to something about that rivet to stop a recurrence.
In terms of replacement, there’s not much in the price between Genuine LR rubber and BAS, Alive and Alisport silicone. I’ll probably go BAS, unless there’s any reason not to.
 2007 110 TDCi Station Wagon XS
Post #855697 12th Sep 2020 6:33pm
jst
mine is without that insulation so one less worry! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #855716 12th Sep 2020 7:18pm
Bluest
Which makes me wonder why it is even there in the first place. 2007 110 TDCi Station Wagon XS
Post #855726 12th Sep 2020 7:26pm
Oldowner
It used to be fitted to CSW models along with the plastic fibre under trays to reduce the drive by noise for various overseas regulations involving it the CSW being classed as a car not a utility vehicle.
Post #855757 12th Sep 2020 10:09pm
The padding was only present in recent years on the XS, I think, and I seriously doubt that it does anything useful.
Post #855758 12th Sep 2020 10:11pm
Thanks for the heads up ~ another thing to check. Thumbs Up
Post #855795 13th Sep 2020 11:45am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Thanks to your post, Bluest, I had a closer look today, and may just have avoided a hose leak Thumbs Up
Now, my 2015 doesn't have the padding anymore, BUT one of the bolts holding the (now plastic) inner wheel arch has ripped a protective sleeve of the turbo hose. Sooner or later, the hose itself would have been damaged, I'm sure (luckily, there is a wire around the hose, which may have protected it).
I put some washer on the bolt, so it isn't going in as far as before.
But you can also see, the hose is rubbing on the inner wheel arch (easy to see, thanks to all the dirt Very Happy )
Any ideas how to improve this situation welcome.
Post #859164 1st Oct 2020 5:40pm
Eduardo
Happens to me some years ago, If I remember well I replace the rivet by a bolt that don't touch the hose.
Cheers! Eduardo
Post #859167 1st Oct 2020 6:02pm
macfrank
So you mean in my case replace the bolt by a rivet? Smile
Post #859168 1st Oct 2020 6:04pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Mine did exactly this in August. The stock rubber hose gets soft with heat and time and moves over to rub against one of the bolts that holds the air box support.
 Roaming around 🇳🇴🇨🇭
Post #859173 1st Oct 2020 6:46pm
macfrank
Shocked Did you just replace the hose or did you add any additional protection?
Post #859202 1st Oct 2020 8:53pm
Angus_Beef
I replaced all of them with BAS silicone hoses which are much more stiff and don’t flex. Soon I’ll add the hose-to-alternator bracket that the rhd cars got. For 95 bucks the BAS hoses were an easy buy for me vs trying to source something else (I was travelling for a month and needed a proper solution, fast) Roaming around 🇳🇴🇨🇭
Post #859204 1st Oct 2020 9:09pm
Can you reverse the direction of the bolt? Or just cut the excess threads off in situ. If you shortened the bolt off the vehicle would you still be able to fit it?
As for the hose moving laterally ~ just try-wrap some foam or sleeve with an old section of hose so it acts as a sacrificial rubbing surface. The harder the material, within reason, the better. I've seen old mountain bike tyres used to good effect.
Post #859222 2nd Oct 2020 5:53am
Angus_Beef
LR053189 (its actually for RHD cars to keep the hose off steering gear) seems like a good addition. I have ordered one to fit. My BAS hose is not rubbing at the moment, but that hose is so long it does move around a bit.
LR057448 & LR053189 Roaming around 🇳🇴🇨🇭
Post #859241 2nd Oct 2020 6:59am
Bluest
Will the LR053189 fit a 2.4? 2007 110 TDCi Station Wagon XS
Post #859242 2nd Oct 2020 7:08am
