Home > Puma (Tdci) > Turbo hose worn through - Not the usual.
Page 2 of 2 <12
macfrank
Thanks gents for all those great suggestions! Thumbs Up
Those brackets seem like a good solution! Should keep the hose away from both bolt and wheel arch. I think there's plenty of room to fit it to my LHD.
I found more on those brackets here https://www.defender2.net/forum/post344810.html
However, I don't see where that second bracket LR057448 is fitted to on the 3rd picture.
For now I'll cut the end off the screw and I'll see where I can find an old bike tyre Smile
edit: bolt cut off, filed down and screwed back in; got no rubber yet, so I used some aluminium tape for now
Post #859356 2nd Oct 2020 3:16pm
Bluest
I’ve today fitted the hose bracket to my 2.4. Looks just the job and a good fix for less than £20. Hose is held nicely away from the inner wing and steering column. Fitting it wasn’t to bad but I had the airbox and wing off already for other reasons. I’d imagine it would be tricky to install with the wing and airbox in place.
 2007 110 TDCi Station Wagon XS
Post #860352 7th Oct 2020 7:57pm
macfrank
That's neat. So you didn't fit that second bracket? I still don't see where it's supposed to be fitted.
Post #860356 7th Oct 2020 8:05pm
Bluest
I did see it on the parts diagram, but I didn’t understand what it did, so just went with this. If anyone this it’s useful, let me know. I might take out the lower air box mount as it is quite close to the hose still and I’m going to fit a Nugget Stuff airbox anyway. 2007 110 TDCi Station Wagon XS
Post #860358 7th Oct 2020 8:11pm
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Hi chaps, the second bracket is secured by the middle bolt of the air filter support. It hold the straight portion leading to the intercooler. Mine is still in the post from the UK - I’ll post up pics as soon as it’s here.
Dave Roaming around 🇳🇴🇨🇭
Post #860361 7th Oct 2020 8:18pm
macfrank
ah, great! Looking forward to see the photos Smile
Post #860362 7th Oct 2020 8:20pm
Page 2 of 2 <12
