Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4787 |
AC is a very easy install. All nuts and bolts, the under dash unit plugs straight in behind the fuse box. The only wiring I had to do was to make an engine overlay harness for the compressor and condenser fan that connects to the ECU via relays
I've started faltering on the engine conversion, Zed. I'm still in love with the Td5 (sad I know ) 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
3rd Sep 2020 5:29pm |
Still haven’t got round to getting mine gassed up yet Ray
3rd Sep 2020 11:04pm |
May as well wait until spring now Ray 2002 90 Td5 Station Wagon
4th Sep 2020 2:36pm |
Ray
4th Sep 2020 3:03pm |
RILEY Member Since: 01 Feb 2013 Location: United Kingdom Posts: 35 |
Read your thread from the start to finish Totally inspiring ,just rewound a couple of posts and all I can say is.......
You can't beat the sound of a Td5 symphony (V8 I know ) Keep the updates coming its a great read one life, sell it |
4th Sep 2020 5:13pm |
Thank you Riley
Having both a V8 and a Td5 means I'm pretty well aurally sorted Talking of updates..... Today I got my Provent mounted up to the wing stay so I can measure the pipe runs. Also, I hadn't realised how rusty my heater box had become. Another job for the list Click image to enlarge Also I sorted out the illumination for the AC. Only the temperature selection (blue one) was lighting dimly. Sorted with a couple LEDs Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
4th Sep 2020 5:42pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
Great hearing this from you George ( sorry ) but i like the 90 SVR the way it is 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
4th Sep 2020 7:44pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
How did you get access to the bulbs? I have tried numerous times to figure out how to get in there.. never found a way. What bulbs did you use? it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
5th Sep 2020 6:14pm |
The panel that the switches are mounted to unclips from the plenum. Once you have access you can pull the knobs off the switches and remove them completely.
The switches come apart by popping the white switch back from the black casing with the 4 tabs. I used 12v warm white LEDs and put the original coloured filters over them You will need to solder the new lamps in place 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
5th Sep 2020 6:53pm |
Not quite sure I follow. When you say "the panel that the switches mounted to", are you referring to the recessed 2 x 3 panel the switches are on, or the entire panel under the dash? it's a Landrover thing...
5th Sep 2020 7:17pm |
The panel that the switches are on. It can be removed from the AC unit - it's tight but there are 4 clips (2 top 2 bottom). 2002 90 Td5 Station Wagon
5th Sep 2020 8:17pm |
I'll give it a try again, prying top and bottom. Now i know that's how it comes apart I will be less worried about breaking things.
Do you have any specs on the LED's you put in? it's a Landrover thing... my renovation thread: http://www.defender2.net/forum/topic40792.html |
6th Sep 2020 12:17am |
They were just little 3mm warm white LEDs with the original colour filter over the top. They came with the appropriate resistor for 12v 2002 90 Td5 Station Wagon
6th Sep 2020 10:25am |
New boots!
The Hankooks were getting below 4mm which is my comfortable lower limit. After lots of searching I ended up fitting Continental ContiCrossContact LX2s. I've dropped from 285/60 r18 to 265/65 r18. The same rolling radius, give or take, but that little bit narrower. To be honest you can't really tell the difference between them and the 285s, but hopefully they'll behave nicer when they wear Anyway, here they are (a bit dark as it took me a while to fit them on my own having never used a tyre machine before! - not a scratch I might add ) Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
10th Sep 2020 7:11pm |
