Home > For Sale & Wanted > [Wanted] Indicator lens for trailer |
They look very much like standard NAS lights. Will be very easy to find (or replace with an LED version). Darren
2nd Aug 2020 8:15am |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
I believe they are the same as NAS units. They are stamped with Pieri as the manufacturer.
Changing to LED is on the to do list, but it's not a priority on the finances just now. Keith |
2nd Aug 2020 8:38am |
Darren,
I'll admit already that I'm struggling to find them easily. So far my only success is thexmod.com (other than lots of options if I want to change to LED units). Keith |
2nd Aug 2020 10:37am |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1549 |
they are not the same as regular nas ones.
different plugs im afraid |
2nd Aug 2020 10:43am |
No worries, I was hoping that as all I need to replace was the lens I may get away with an easier search/better compatibility.
Looks like it will be a full unit (roughly the same price as a NAS LED lamp). Perhaps my original ones will be worth selling if and when I do change to LED. Keith |
2nd Aug 2020 10:47am |
ill have the old ones off you as i have 2 broken ones as well
std nas led fit you need to solder on new plugs to all the light looms |
2nd Aug 2020 11:03am |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 306 |
Just for my clarity... Is the Military Land Rover one the same as the Penman trailer one? Or is it just the Penman that is unique? |
2nd Aug 2020 11:09am |
nope the penman trailer plugs that i have and have had are all different. eg the ind only fits that plug so you cant fit the wrong lens etc..
they tired tp make them squaddie proof all it means is you get loads of them taped in place |
2nd Aug 2020 11:15am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2213 |
Is the lamp holder not interchangeable between the LR one and the MOD one? 02' 110 TD5 Double Cab Rebuild Thread
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
2nd Aug 2020 11:19am |
Picture of the broken lens
Click image to enlarge And the holder from the rear Click image to enlarge The rear of the adjacent stop/tail has a different plug as it has 3 wires terminated instead of the two on the indicator. I have no idea how these compare to other military units but they're different to those on my 110 as the holders didn't have the 90 at the back for the plugs to connect from underneath. Keith |
2nd Aug 2020 11:32am |
nope they are different in the lug fixing positions.
i have seen them cut off and taped and or glued in place the part number on them works find and a couple of suppliers stock them but they are dearer than std 95mm ones |
2nd Aug 2020 11:47am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1358 |
Does the grey plug on the back of the light come off, leaving it looking like this?
If so, a standard civilian type lamp can be used, refit your grey bit. Click image to enlarge Edit, just read MDM's post, it seems they're completely different housings. |
2nd Aug 2020 11:50am |
I had wondered about just switching the amber lens over, however I'm not having much lunch finding any non military units online either Keith
2nd Aug 2020 11:55am |
Flatdog,
https://www.flatdoguk.com/nas-indicator-amber~1389 The Perei one are better quality, but if it's a temporary fix, cutting the lens off and fixing it to your old housing, a Wipac one above should be ok. Last edited by DSC-off on 2nd Aug 2020 12:09pm. Edited 1 time in total |
2nd Aug 2020 12:05pm |
