Home > For Sale & Wanted > [Wanted] Indicator lens for trailer
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Does anyone have a take off indicator lens for putting on a Penman trailer, I have one broken on the trailer I collected from Brightwells last week.
It's a 95mm lens on the trailer, thought I would ask here if anyone has a unit to sell before starting to hunt on ebay etc.
Thanks Keith
Post #847539 2nd Aug 2020 7:00am
They look very much like standard NAS lights. Will be very easy to find (or replace with an LED version). Darren
Post #847541 2nd Aug 2020 7:15am
Keith5
I believe they are the same as NAS units. They are stamped with Pieri as the manufacturer.
Changing to LED is on the to do list, but it's not a priority on the finances just now. Thumbs Up Keith
Post #847544 2nd Aug 2020 7:38am
Keith5
Darren,
I'll admit already that I'm struggling to find them easily. So far my only success is thexmod.com (other than lots of options if I want to change to LED units). Keith
Post #847566 2nd Aug 2020 9:37am
Mdm
they are not the same as regular nas ones.
different plugs im afraid
Post #847568 2nd Aug 2020 9:43am
Keith5
No worries, I was hoping that as all I need to replace was the lens I may get away with an easier search/better compatibility.
Looks like it will be a full unit (roughly the same price as a NAS LED lamp). Perhaps my original ones will be worth selling if and when I do change to LED. Keith
Post #847572 2nd Aug 2020 9:47am
Mdm
ill have the old ones off you as i have 2 broken ones as well
std nas led fit you need to solder on new plugs to all the light looms
Post #847575 2nd Aug 2020 10:03am
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
Just for my clarity...
Is the Military Land Rover one the same as the Penman trailer one?
Or is it just the Penman that is unique?
Post #847576 2nd Aug 2020 10:09am
Mdm
nope the penman trailer plugs that i have and have had are all different. eg the ind only fits that plug so you cant fit the wrong lens etc..
they tired tp make them squaddie proof
all it means is you get loads of them taped in place
Post #847578 2nd Aug 2020 10:15am
rallysteve
Is the lamp holder not interchangeable between the LR one and the MOD one? 02' 110 TD5 Double Cab Rebuild Thread
Post #847580 2nd Aug 2020 10:19am
Keith5
Picture of the broken lens
And the holder from the rear
The rear of the adjacent stop/tail has a different plug as it has 3 wires terminated instead of the two on the indicator. I have no idea how these compare to other military units but they're different to those on my 110 as the holders didn't have the 90 at the back for the plugs to connect from underneath. Keith
Post #847587 2nd Aug 2020 10:32am
Mdm
nope they are different in the lug fixing positions.
i have seen them cut off and taped and or glued in place
the part number on them works find and a couple of suppliers stock them but they are dearer than std 95mm ones
Post #847592 2nd Aug 2020 10:47am
DSC-off
Does the grey plug on the back of the light come off, leaving it looking like this?
If so, a standard civilian type lamp can be used, refit your grey bit.
Edit, just read MDM's post, it seems they're completely different housings.
Post #847593 2nd Aug 2020 10:50am
Keith5
I had wondered about just switching the amber lens over, however I'm not having much lunch finding any non military units online either Keith
Post #847594 2nd Aug 2020 10:55am
DSC-off
Flatdog,
https://www.flatdoguk.com/nas-indicator-amber~1389
The Perei one are better quality, but if it's a temporary fix, cutting the lens off and fixing it to your old housing, a Wipac one above should be ok.
Post #847597 2nd Aug 2020 11:05am
