![]() | Home > Series Land Rovers > 52HG25 lightweight series 3 |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3390 ![]() ![]() |
You can get some of it for free at www.merlinarchive.uk
Here's yours... ![]() Click image to enlarge |
Ah fantastic didn’t know it was that easy
![]() ![]() ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
You should be able to get the full B card here: https://www.rlcarchive.org/Help/VehicleBCards
Awesome cheers camelman
![]() Took a long drive home today after visiting the parents (now we are allowed in our “bubble”) and stopped off at one of my favourite places for a quick pic and axle stretch. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Well been doing some deals and swaps with a friend for some bits towards the lightweight over the last few days:
Correct dash with multiple layers of paint, nitromos dug out and cleaning in progress: ![]() Click image to enlarge ![]() Click image to enlarge Also managed to get a few bits to start removing the carling switches and bring her back to military spec: ![]() Click image to enlarge As she only had one fuel tank and no tap I’ve managed to source some take offs to overhaul and then fit: ![]() Click image to enlarge I’ve also picked a few bits off the ![]() ![]() So it’s all slowly coming together, currently in talks about reinstatement of the FFR parts.... hmmm when does it stop ![]() ![]() ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
Ex-SSE 110 there too, wonder if it's one I drove when I was working there? 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
That’s is, see my Buggsy link below
Ah jolly good. It isn't one I drove but I did drive a few of the same spec. 2011 110 USW
Well today I finally managed to get the first two coats of NATO green on and got rid of that horrible ww2 of green
![]() I’m once again going for an in service paint job so a good key sanding and removal of the POs excessive runs etc was all the treatment she got, the windscreen frame had a quick blast of etch primer prior to painting. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
Looking good mate. Keep up the good work and awesome effort. Worth it in the end. Fortunately I’m mostly done , if there is such a thing as “done”
![]() Click image to enlarge ![]() Click image to enlarge |
Cheers Keith
![]() What was the choice in going RCT / RLC? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Well I’ve managed to get the NATO green and black on
![]() ![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Second tank wire wheeled, rust treated and first layer of paint applied.
![]() Click image to enlarge Also treated and painted the servo to tidy up under the bonnet. ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Black paint and wire wheel was out again this morning before work, second coat done on the tank, pedals now black instead of rusty brown and the chassis rail that’s soon to be hidden by the second tank was cleaned and painted also.
Bit more work on the rear chassis and suspension yesterday, wire wheeled and painted
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
