Home > Series Land Rovers > 52HG25 lightweight series 3
Page 1 of 5 12345>
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Well as if 2 defenders, 1 90 and a disco 3 weren’t enough green ovals in my life I finally have fulfilled two dreams in one today, own a leaf sprung Land Rover and own a lightweight, talking to a friend he had lost interest in owning it due to a rough gearbox and a few other mechanical problems he wanted it gone, the price he asked was so good I agreed to purchase it for my fleet, now I just have to build a carport for her Rolling with laughter
So here is 52HG25 as I picked her up today, she needs some parts to bring her back to military specs but that is something to happen over a while not an requirement straight away, with the summer coming and Guernsey getting the Covid-19 under control we should soon be allowed to enjoy summer days and evenings with the canvas off and a nice sunset in view Thumbs Up
 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #830280 10th May 2020 2:33pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Very nice. Good luck with the refurbishment, but it looks good anyway!
Post #830293 10th May 2020 3:08pm
Mash
Relatively straight, chassis needs a clean and paint, foot wells will need doing soon, it’s mainly going over brakes/clutch etc Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #830308 10th May 2020 3:31pm
90 Dreamer
Cracker
Post #830310 10th May 2020 3:40pm
CarMan
Thumbs Up Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #830314 10th May 2020 3:54pm
L110CDL
Very nice Mash Thumbs Up Clayton.
Keeper.
Post #831304 15th May 2020 9:42pm
What happened to the windscreen vents?
Post #831331 16th May 2020 6:29am
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Nice one Thumbs Up cheers Paul
Post #831339 16th May 2020 7:27am
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
Lovely Thumbs Up . My first LR was a lightweight and i'd love another one.
Post #831349 16th May 2020 8:01am
camelman
Welcome to the gang 😎
Post #831383 16th May 2020 11:07am
Mash
Cheers guys Thumbs Up
The vent panel was extremely rotten so the PO had this plain one made and the old brackets cut off the original and welded to this one, did he remember to remove all the brackets/ fly screens etc? No did he Censored Banging Head Banging Head more to add to the list of a new one then.
Well after owning her for a few days and bleeding the brakes twice they still needed a double pump to get them to work correctly, the po said he had redone all the brakes a month or so ago, so with that knowledge a full strip down revealed a common mistake of reassembly.
As you can hopefully see the spring has been connected between the two shoes apposed to the leading show and the pin on the back plate. This can cause a “spongy” brake pedal feeling, also the adjusting cams on 3 of the wheel stations had been hacksawed off and replaced with an aftermarket kit that was also incorrectly fitted causing the shoes to bind on the backplate and drum.
With the brakes apart and finding an old tin of calliper paint this made sense.
Now the brakes are working well, onto the engine it’s a little sluggish to start and cuts out every now and then, well the original battery it came with was a gel battery that had m6 fixing so an extended bolt with penny washers made the connection Rolling Eyes so a rummage at the back of the shed found this:
The fuel issue turned out to be a slight seep from the lift pump to carb, a quick nip with the spanner and a little fettle of the idle adjustment and I’ve got a sewing machine under the bonnet Cool Very Happy
With all that work done it’s definitely time for her to earn her keep:
So the next few things to do, get a correct vent panel, find some S3 wheels or later defender steels, get the correct 7 leaf springs then some paint to get rid of the horrible ww2 American green paint (back to good old NATO green/black) oh and continue the search for a whole host of other parts Rolling with laughter Rolling with laughter 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #831736 18th May 2020 9:03am
camelman
Decent vent panels are fetching strong money at the moment, even rotten ones are getting a couple of hundred quid.
When I bought 05KD65, the vent panel end was rotten. There is a chap on facebook who does fantastic repairs at really reasonable rates, search for "The Welding Wood".
Post #831743 18th May 2020 9:33am
Mash
Thumbs Up Cheers for the heads up camelman, I have been able to acquire a rotten one off an old friend who is doing up a Dutch lightweight as he was given a new one with the buy. Not sure where it was from but didn’t look bad. The only problem is £700 for a new one is nearly the same as a whole bulkhead Shocked
Excellent lightweight btw, what’s the history behind it? I assume there is a thread I have missed Embarassed 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #831749 18th May 2020 10:08am
camelman
05KD65 was the last lightweight registered with the military (in 1985) and spent 10 years with the Red Arrows being sold to its previous owner (who didn't know it was the last one....)
I've owned 05KD63 for 15 years and spent a couple of years looking for this one.
It popped up on ebay a couple of years back and only 1 other person bid on it Smile
Currently stripped down while I rebuild her.
Post #831751 18th May 2020 10:28am
Mash
Fantastic history that, always great to see the rare and unique ones saved and looked after 👍🏻 Will at some point soon ask for the merlin report on mine. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #831780 18th May 2020 12:36pm
Page 1 of 5 12345>
