Page 1267 of 1379 <123 ... 126612671268 ... 137713781379>
jieming
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Fitted a bridge across the clutch switch and FINALLY after four years of tolerating the accelerator pedal having mind of its own it now does what my right foot is telling it to do!!!!
Finding this hack is a classic example of why this is such a great forum!
Post #832356 21st May 2020 11:06am
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Unpacked this little lot today. Just waiting for the Dinitrol to come then it’s fitting time.
Post #832362 21st May 2020 11:33am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Similar for me - trying some spring isolators on the front - just waiting for the turrets to arrive.
 Rgds.
Chris
Post #832430 21st May 2020 6:05pm
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
Went with my friend to buy this 110. Had a defender2.net sticker in the windscreen, was it anyones here ?
Post #832444 21st May 2020 6:40pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Thought I better sort my crossmember out before I fit my new wheel carrier
Lovely!
Post #832464 21st May 2020 7:26pm
Unless you're planning to fit them top and bottom to gain a bit of height, they really should be fitted at the top to get the most out of them. Then, if you do that the Disco II version is a better bet as it effectively has a built in securing ring and better protected bolts:
 Darren
Post #832479 21st May 2020 8:09pm
You won’t regret the castellated spring isolators. I have them on mine top and bottom all around with D44 turrets.
They give a little lift but remove a lot of mild vibration from the road. No Guts, No Glory.
Post #832486 21st May 2020 8:51pm
Pacha
Thanks Darren - still waiting for some hardware so will swap them to the top. Rgds.
Chris
Post #832491 21st May 2020 9:07pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Yes, fit them top and bottom. Thumbs Up
I’ve also got the Disco 2 ones at the top as well.
Gives a much nicer ride.
Post #832493 21st May 2020 9:18pm
Danny Fireblade
Sorry to be thick but what’s the reason for the spring isolators? What do they do?
Post #832498 21st May 2020 9:41pm
nitram17
Simply reduce road vibration when put on the top of the spring ....less effective on the bottom.
Post #832500 21st May 2020 10:14pm
Danny Fireblade
Thanks, what's the best type to get to go with my package above?
Post #832507 21st May 2020 11:48pm
nitram17
looks like you have already bought the top turret spacer so the disco ones would be a waste of cash just use the castellated rubber ones top and bottom!some folk pay the extra expense and buy the land rover ones but as long as you dont get them from pound and the mid price range ones are ok!
https://www.ebay.co.uk/itm/Rear-Spring-Iso...Swdppee806
https://rimmerbros.com/Item--i-ANR2938
https://www.island-4x4.co.uk/spring-isolat...-4889.html
https://www.lrdirect.com/ANR2938-Isolator-Rear-Coil-Spring-Rr/
Post #832509 22nd May 2020 1:29am
Danny Fireblade
Thats great, thank you.
You have pretty much answered one of the questions I just asked in the maintenance section. Thumbs Up
Post #832511 22nd May 2020 1:35am
excossack
New toy day, A hydraulic crimping tool so I can re-make the Anderson connector plugs amongst others. Saves using a vice with a home made crimp. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #832541 22nd May 2020 9:19am
