Home > My Defender > What Did You Do In Your Defender Today |
jieming Member Since: 21 Feb 2016 Location: Kent Posts: 30 |
Fitted a bridge across the clutch switch and FINALLY after four years of tolerating the accelerator pedal having mind of its own it now does what my right foot is telling it to do!!!!
Finding this hack is a classic example of why this is such a great forum! |
21st May 2020 11:06am |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Similar for me - trying some spring isolators on the front - just waiting for the turrets to arrive.
Click image to enlarge Rgds. Chris |
21st May 2020 6:05pm |
L90DNY Member Since: 09 Feb 2016 Location: Somerset Posts: 117 |
Went with my friend to buy this 110. Had a defender2.net sticker in the windscreen, was it anyones here ?
Click image to enlarge |
21st May 2020 6:40pm |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 162 |
Click image to enlarge Thought I better sort my crossmember out before I fit my new wheel carrier Click image to enlarge Lovely! Click image to enlarge |
21st May 2020 7:26pm |
Unless you're planning to fit them top and bottom to gain a bit of height, they really should be fitted at the top to get the most out of them. Then, if you do that the Disco II version is a better bet as it effectively has a built in securing ring and better protected bolts: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
21st May 2020 8:09pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20443 |
You won’t regret the castellated spring isolators. I have them on mine top and bottom all around with D44 turrets.
They give a little lift but remove a lot of mild vibration from the road. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st May 2020 8:51pm |
Thanks Darren - still waiting for some hardware so will swap them to the top. Rgds. Chris |
21st May 2020 9:07pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2040 |
Yes, fit them top and bottom.
I’ve also got the Disco 2 ones at the top as well. Gives a much nicer ride. |
21st May 2020 9:18pm |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 319 |
Sorry to be thick but what’s the reason for the spring isolators? What do they do?
21st May 2020 9:41pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Simply reduce road vibration when put on the top of the spring ....less effective on the bottom.
21st May 2020 10:14pm |
Thanks, what's the best type to get to go with my package above?
21st May 2020 11:48pm |
looks like you have already bought the top turret spacer so the disco ones would be a waste of cash just use the castellated rubber ones top and bottom!some folk pay the extra expense and buy the land rover ones but as long as you dont get them from pound and the mid price range ones are ok!
https://www.ebay.co.uk/itm/Rear-Spring-Iso...Swdppee806 https://rimmerbros.com/Item--i-ANR2938 https://www.island-4x4.co.uk/spring-isolat...-4889.html https://www.lrdirect.com/ANR2938-Isolator-Rear-Coil-Spring-Rr/ |
22nd May 2020 1:29am |
Thats great, thank you.
You have pretty much answered one of the questions I just asked in the maintenance section. |
22nd May 2020 1:35am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
New toy day, A hydraulic crimping tool so I can re-make the Anderson connector plugs amongst others. Saves using a vice with a home made crimp. 1999 Defender TD5 110
22nd May 2020 9:19am |
