Home > Maintenance & Modifications > LOF POWERspring pedal assist |
Roger Member Since: 26 Apr 2018 Location: Hampshire Posts: 71 |
Fitted this today after putting the job of for a while as most on here found it a pig to do.
Took me 15-20 mins and was no effort at all (largely due to experience gleaned here) so here is a breakdown of how i did it: Step 1 Depress the clutch to remove the old spring - with the clutch depressed you can lift the square loop bit of the old spring off with big red (large flat bladed screwdriver that does all the jimmying and prying jobs). Don't mess about with cutting pieces to length, the below set up of scraps worked fine. Click image to enlarge Step 2 Compress the LOF POWERspring - usually done in a vice, for some strange reason i don't have one so used some irwin quick grip clamps and was terrified of the spring popping out and hurting me! Once clamped use some reasonably thick cable ties to hold it compressed. Click image to enlarge Step 3 (and this is where it can be a 15min or 3hr job!) Free the clutch pedal so that you can fit the POWERspring completely from behind the pedal, keeping the pedal out of the way! If you are replacing any of the bushings do it now before you start, i only needed to replace the central bush as the other two were fine. Click image to enlarge Step 4 Get the left prong in and you will notice that due to the spring being under tension the right prong won't line up and both prongs are too close together to seat the right one properly if you do get it in. Click image to enlarge Step 5 Get some mole grips on the extreme left of the left hand prong poking out the other side of its bushing (I did have some fancy auto-grip needle nose mole grips but they were pants so i just used my normal cheapo ones). Click image to enlarge Step 6 Use a screwdriver to lever against the pedal and get the right hand prong into its bushing (this takes very little force as you are only spreading the currently deformed spring rather than loading it) - you can guide the right prong while spreading by holding onto the right hand coil, i just didn't have enough hands to photo that as well. Click image to enlarge Step 7 While using the screwdriver to hold the right prong in, depress the pedal and jam it down again. (there was just enough tension on the screwdriver to allow my free hand to take the picture) Click image to enlarge Step 8 Remove the screwdriver and mole grips then lever through the spring holes to bring the spring forward so that the central mount lines up with the recess on the back of the pedal. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Step 9 Cut the cable ties while you keep the spring held forward the same way as the step above (the ties are under a lot of tension so cut very easily). Click image to enlarge And that is it done, just check it is fully seated (i needed to pry the right hand prong back into place as it was half out due to cutting left cable tie first) Click image to enlarge Click image to enlarge |
1st Mar 2020 12:42pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Awesome explanation - I've been putting off fitting mine due to the faff involved
2nd Mar 2020 1:59pm |
The cable ties are the key - thanks!
I did it differently, keeping the pedal pushed down doing it all from the front. I compressed the spring in a vice and cable-tied it so it was an exact fit. Then hooked in the "U" part of the spring at the back of the pedal and wiggled the arms into the bushings. The critical part was keeping the "U" hooked in when releasing everything, so I put a bit of rope through the coils and pulled down and back whilst using a storm lighter to melt the ties (easier and quicker when one handed). Released the pedal, then the rope and job done p.s. I also bent the little brackets (with the spring arm bushings) inwards slightly, as the LOF spring is quite a bit narrower than the original and the seating looked a bit iffy. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
13th Mar 2020 1:24pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Dickie Davies here, with World of Sport!
I've just fitted mine this afternoon. It only took about ten minutes... once I'd struggled for a couple of hours (including fitting it back to front - it's quite challenging to remove when you do that). But the cable ties were key in the end, so many thanks for the guide, above. I'll have to report back on how it feels tomorrow once I've used it for work. |
16th Mar 2020 4:23pm |
After a few days, I can say it's a massive improvement. You might not realise at first but then try sitting in a traffic jam for an hour (they've closed the borders here and people are being stupid...)
Why on earth didn't LR make it standard Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
16th Mar 2020 5:19pm |
I've been pleased with mine driving around today. It's certainly lighter, and my clapped out knee appreciates that, but as I think has been said elsewhere, being a 2.2, it's not really 45% lighter. I'd suggest about 20%, but definitely a worthwhile improvement and well worth the money.
17th Mar 2020 4:29pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1913 |
May try this tomorrow 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
3rd May 2020 9:44pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 874 |
Try the LOF master clutch cylinder with this spring. I noticed a small difference with the spring, but a massive difference with the master cylinder. A bit more of a pain to fit, but well worth it.
4th May 2020 12:48pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
FOR SALE
I have a brand new in packaging one of these, only not fitted as I have the LOF master cylinder happy to post to anyone whom wants it and lives in mainland UK for £15, DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
4th May 2020 2:19pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
I’m waiting for the video 🤔
4th May 2020 6:35pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2212 |
Ok another mod I’ll have to fit just because every one else has done it.
LR90. I’ll take your spare one please. Thanks for the saving. PM sent Keith |
4th May 2020 6:55pm |
Roger, Ive been putting this off since I bought it at Peterborough last year!
I followed your instructions and within 15 mins it was fitted Actually enjoyed fitting it, the worst part was compressing the spring in the vice and the fear of it springing out I put a zip tie through the spring and bottom of the vice just in case The actual install was very easy and it has made a decent improvement over the original Thanks for the tips 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
7th May 2020 10:37pm |
24heuer Member Since: 21 Jul 2015 Location: Edinburgh Posts: 167 |
just done this.
Tried the cable tie method many times and failed yesterday evening - i just couldn't get anything to line up and stay lined up. I had to give up I was getting so mad! Had another go this morning using the LOF method with some thin nosed mole grips and brute force - it took 10 minutes maximum. I'd recommend trying this way first. Unfortunately with all the messing about yesterday I damaged the u shaped bush that sits in the pedal so I have it all to do again at some point! Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
6th Sep 2020 9:57am |
914PAW Member Since: 01 Feb 2021 Location: Wiltshire Posts: 14 |
Many thanks particularly Roger, really good step by step guide. I’ve just done this on my 03 TD5 and it took about 30 minutes using the strong cable tie technique. Although the clutch isn’t that bad on my Defender it does give my left knee a bit of a work out if it’s stop start. So I’m hoping this just takes the edge off that. Will post experience when I’ve driven her for a few days.
20th Feb 2021 2:09pm |
