![]() | Home > In Car Electronics > Nakatanenga DAB antenna |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
Yes, good point, I had forgotten that! To every rule there is an exception.
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
Hi - Think I have an old Entreq DAB aerial from Brendan in the garage which I never got around to fitting ... any reason why I shouldn't use this instead of buying a new Nakatanega ?
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2230 ![]() ![]() |
Just purchased this antenna from Brendan.
Questions: 1. Is this black and red to go somewhere? 2. Does the whole dash panel have to come off to route the cable? Cheers for helping. ![]() Click image to enlarge ![]() Click image to enlarge |
Argee Member Since: 13 Nov 2017 Location: Suffolk Posts: 71 ![]() ![]() ![]() |
Yes, centre panel out, 2 screws, unplug all the switches on the right and the clock, don’t worry, the plugs are unique to the switch they serve so can only plug it back together correctly.
As for the wires, see posts on previous page. Good luck! |
Great thanks. on it now.
Keith |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Black / red is the boosters power.
If you have no extra Amps fitted you can connect red to the HU’s rear Blue / white tracer remote and the ground to a suitable ground point. This way it’s only powered when required when the HU is powered up and off otherwise. ![]() ⛽️🛢️⚙️🧰💪 |
Thanks for the help. 10 min job. Using the pull through method.
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 320 ![]() ![]() ![]() |
I fitted my aerial this morning. Hardest thing was removing the speedo cable to get behind the dash.
I pick up DAB with a signal strength of between 38-40 so just need to do some driving to see how it holds up. |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 ![]() ![]() ![]() |
Entreq one will be at least as good if not better. Only based on their other products, no real knowledge of either aeriel |
[quote="keith"]Thanks for the help. 10 min job. Using the pull through method.
Got any details of this method ? ... want to try fitting my new Entreq aerial at weekend ... |
When I pulled my aerial though I used green pvc coated wire, make a loop at the end so no sharp end is protruding. Tape up. Then tape that to the aerial tip, so the aerial end is protected by the tape and facing forward though the grommet. I use 3M blue tape Witt a tear off tab on the end so it’s easy just to rip it off once though.
Take off the horizontal facia just below the dash dials with a T30 bit I think it is, to the left there will be a hole pretty much in line with that grommet. Use a head torch and you will be able to see camping going though. You can pull though here, leaving centre dash in place. Then once that stage is done another day if you are short of time you can then take the centre dash off and into the back. The T30 torch screws are 2NM when re-tightened. No other dash part needs to come off but this allows better access providing you don’t have giant hands. At worst you can at least see. Long nosed pliers can help to carefully take hold of it to bring the end though, even more so if you have help from the engine bay side. I managed it on my own. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Ladies and gents,
I'm 99% of the way there with my install. I just need a steer on the easiest place to pick up live and connect to earth for the amplifier. I've read the previous posts. But unsure where exactly you mean the the way to route it. "Correct, there is a stud on the bonnet opening mech handle assemble that would suffice as a ring terminal for a ground. " A photo would be really handy if possible. I'm on a blaupunkt with no lives coming out hence the need to link into both. Can anyone help? Defender 90 XS TD5 (03 Reg) |
Just behind the handle that you use to open the bonnet in the footwell there is a suitable metal stud and nut you can fit a grounding point eye onto providing it isn’t a large cable. Chillin In The Backwoods🇬🇧🇺🇸
