Home > Maintenance & Modifications > BAS intercooler fitting?
bear100
Had fantastic service from Pete Bell at BAS, ordered an intercooler, silicone hose kit and new clamps yesterday and this morning at 8am it arrived! Cheers Pete đź‘Ť
Now how the hell do I fit this thing? Any tips?
Thumbs Up Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #827142 23rd Apr 2020 8:44am
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
When you take the old one off you have answered the question!
Front panel has to come off, and the support braces.
I think I had to trim the fan shroud a little to get mine to sit right.
One of the hoses is a PITA to get hooked on, it’s the one that bends back on itself.
Then put back together.
Might be worth a search of YouTube...
Post #827146 23rd Apr 2020 9:02am
hank
All pretty self explanatory when you start spannering. The radiator needs two plastic lugs trimming off, which caused me some head scratching for a while. Other than that, pretty simple... If not tight and knuckle damaging.
See here for details https://www.defender2.net/forum/topic67250.html > 110 XS Double Cab
Post #827152 23rd Apr 2020 9:30am
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
The 90 degree hose that fits on the left of the engine low down is THE entertaining bit. You may be tempted not to fit it, but it can be done, and without loosening the water pump as you may find suggested elsewhere.
You need to undo the steel pipe that connects it to the left hand intercooler hose, fit it to the manifold first, and put on the Jubilee clips loosely before you put the steel hose on. I used a flexible Jubilee clip screwdriver to tighten them up. It's impossible without one.
If you have a search back through my posts (I can't as I'm on my phone) for March 2019, there should be more details and a few useful links.
The skin grafts are now pretty much healed too....
Post #827175 23rd Apr 2020 12:01pm
Co1
Which BAS map do you have, assuming you have one? Interested to know what difference this makes so make sure you let us know once fitted. Thumbs Up
Post #827247 23rd Apr 2020 5:11pm
bear100
All done, thanks for the tips peeps, got to be honest it was a Censored of a job to do!
Cut pretty much every knuckle Shocked.....big hand syndrome!
oh well its done now Very Happy
Co1 i expect it won't give anything noticeable in terms of performance but it will keep my exhaust gas temperature down which is more my concern tbh, i will let you know how i get on Thumbs Up Thumbs Up 2023 Defender L663 V8
Post #827256 23rd Apr 2020 6:04pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
You will notice torque is improved straight away and pick up 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #827257 23rd Apr 2020 6:05pm
Co1
Cheers. Why is EGT a concern for you, are you running high at the moment?
Post #827259 23rd Apr 2020 6:13pm
bear100
Mr. Green Mr. Green Mr. Green Bonus!!!!!! 2023 Defender L663 V8
Post #827260 23rd Apr 2020 6:16pm
bear100
The remap will increase the EGT as a matter of course, plus i will be overlanding at some stage in Morocco and the Pyrenees (just to name a few) and very conscious of the temperature.
I have noticed when towing heavy loads it climbs up too high for my liking, so wanted something to help really
Post #827262 23rd Apr 2020 6:22pm
ZeDefender
I borrowed/added to these notes when I did mine:
Remember to tie the bonnet up to something because you wont be able to use the bonnet stay as that will need to come off.
Remove fan cowling and grill.
Loosen 2 bolts on bottom of AC radiator housing.
Remove only right side 2 b"bolts" of the bonnet catch plate on the radiator side of fender by using a vice grip (you will destroy these 2 bolts so make sure you have 2 spare bolts to replace these! I used normal bolts for future ease) OR use 2 nuts to lock then undo.
Loosen 2 I C pipes and bolts.
Pull old I C.
Use a loose hack saw blade to trim down the two pieces of protruding plastic at the bottom of the radiator.
Pop new I C in (it will be a tight fit) and secure bolts and pipes.
Then put everything back Very Happy Tell someone you love them today because life is short.
Post #827264 23rd Apr 2020 7:00pm
Joe the Plumber
I wouldn't get too excited about potential performance increases. I fitted my BAS intercooler and hoses a few weeks after having the BAS 170 remap and it made no appreciable difference.
However, it does open up the way to Pete's uprated turbo....
Post #827273 23rd Apr 2020 7:50pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Thumbs Up
Hi, I’m not watering ya bonfire , but a few of the companies that run trips in Morocco etc, won’t take trucks with large full width inter coolers,
Worth checking if ya going down that route Thumbs Up
Post #827274 23rd Apr 2020 7:53pm
bear100
Joe the thought never crossed my mind Whistle
Daisy90 Shocked why would that be? Surely it would be better than a standard? 2023 Defender L663 V8
Post #827276 23rd Apr 2020 8:03pm
jst
Thumbs Up
are they worried about engine cooling ? worried it blocks the rad?
which companies? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #827281 23rd Apr 2020 8:19pm
