Home > Maintenance & Modifications > LOF Powermaster Install tips
Page 2 of 3 <123>
Co1
Got the bolts out. Can’t brake the seal of the mastic and gasket now! Assuming I do, I can’t see a way to get it out without removing the brake lines that run across the top. Am going to have a brew and then put the bolts back in and send it back to LOF!
Post #826190 18th Apr 2020 11:59am
Mo Murphy
Confused
Oh blimey that's helpful !
50 Shades of Pennine Grey
Post #826194 18th Apr 2020 12:13pm
Co1
Having slept on it, I might have another go next weekend! Rolling Eyes
Post #826317 19th Apr 2020 7:06am
PCM
Good man.
I'll be doing mine soon so let us know how you get on. Not even looked under the hood to check the brake lines yet. Shocked
Post #826334 19th Apr 2020 9:22am
Mo Murphy
Good show.
If it were me I'd be looking at rerouting those pipes for future changes if the vehicle is a keeper, maybe across the front of the drivers footwell.
Post #826336 19th Apr 2020 9:48am
Co1
Now there’s a thought.
Post #826341 19th Apr 2020 9:59am
Co1
Had a chat with Luke at LOF today who was super helpful. He thinks it can be done without removing the pedal, which is great because there is so much sealant on mine I might have the only defender in the world with a guaranteed leak free clutch pedal to bulkhead joint!
He gave me a few pointers and I’ll have another crack this weekend. I’ll take plenty of pics and put a write up on here for future reference.
Post #826609 20th Apr 2020 6:01pm
sgreenham
United Kingdom 2010 Defender 90 Puma 2.4 HT Galway Green
Thanks for tackling this, I fancy doing mine but I will let you work it out first Laughing
Post #826691 20th Apr 2020 9:22pm
Co1
My pleasure!
Post #826721 21st Apr 2020 5:05am
Co1
Right then, second attempt! Removal time. As you can see, things are tight.
I was trying to remove the nylon nut off the end of the pushrod, but access was super tight, so:
With the pedal jammed down it was a piece of cake to remove the nut.
Then set about disconnected the pipe and switch assembly to give better access to the top pedal box nut. All pretty straight forward.
Next is the bottom nut. Tricky to say the least. With a 10mm ratchet spanner inserted up from inside the cab, and a 13mm fished through the legs of the coolant header, the nut can slowly be removed and then the master cylinder can be eased out.
Post #827572 25th Apr 2020 11:03am
Co1
With the master cylinder out, I lined it up with the new one to set the 2 locking nuts in place to get the biting point in more or less the same place as the other. These are 14mm.
Given how difficult it was to thread the 13mm spanner onto the nut on the bottom fixing to the pedal box, there was no way I would get my hand in there to put the nut back on. So, with some 5 minute epoxy, I glued it on instead.
While it sets. I’m off for a sandwich.
Post #827573 25th Apr 2020 11:07am
Sulisuli
Good work Co1 Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #827574 25th Apr 2020 11:08am
Co1
Reassembly is the reverse, obviously. 100% recommend glueing the nut on the back, I can’t think how I would have done it other wise.
Luke says 25 mins on his website. I was close, 2.5hrs!
Clutch wise, big improvement. As light as the wife’s disco sport.
Post #827580 25th Apr 2020 12:37pm
Mo Murphy
Still worth considering moving those pipes then Co1. It really is sooooooooo much easier on the bench.
Glad you're sorted now Thumbs Up
Post #827595 25th Apr 2020 2:01pm
Co1
Cheers Mo.
Post #827598 25th Apr 2020 2:20pm
Page 2 of 3 <123>
