![]() | Home > Maintenance & Modifications > LOF Powermaster Install tips |
sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145 ![]() ![]() ![]() |
Nice job!
fatnold Member Since: 04 Mar 2018 Location: Sydney Posts: 8 ![]() ![]() ![]() |
thanks for the post. Today's project.
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 ![]() ![]() ![]() |
Is anyone else having the problem where the operating rod bottoms out against the wall of the pedal tower?
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2278 ![]() ![]() |
I’m about to do a master cylinder change on my friends 2.4... any reason I can’t fit the bottom bolt through the master cylinder and the nut on in the footwell, I.e reversing how it was fitted at the factory and avoiding the need to glue the nut to the master cylinder ? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
Not sure. Possible clearance issues getting the bolt through? Can’t see why it wouldn’t be worth a try though.
Thx Co1, was there any issues removing the unbolted master cylinder from the pedal box as there does not seem much room between the back of the master cylinder and the bulkhead, looks about 30-50mm gap.
From memory it was fine. The brake lines make access a bit difficult if your run across the top off the box, but it don’t recall any issues.
Thanks to Co1’s posts here I changed the master cylinder, for a LOF power master one, on my friends 2.4 today.
![]() Took about 2 hours in all. Getting that lower bolt out is a two person job. I used an S shaped/type 13mm ring spanner to hold the lower nut ( in engine bay) and my friend a 10mm ratchet spanner to loosen the bolt from inside the footwell. You can’t do it without the ratchet ring spanner as there is not enough room. The S shaped 13mm spanner I got on the nut from the left side ( viewed while facing the bulkhead) and used my fingers from the right side to guide it onto the nut by feel. Once bolt was loosened I could just spin nut off with fingers while friend held bolt with ratchet ring spanner inside footwel. Keeping hold of the nut to withdraw it is hard and it dropped to the back of the pedal box, but easy to retrieve once master cylinder is out. On reassembly my friend pushed the bolt back in from footwell and held there with ratchet spanner and fingers and I managed to spin the nut on with my fingers from right hand side. Ps my hands are not small but managed to do it first time. Have a magnet on a stick ready to retrieve it if you drop it . Else use Co1’s method of gluing nut to MC. I then fitted the S shaped 13 mm ring spanner on the nut as per above, spanner from left hand side using fingers from right hand side to guide onto nut. Then from inside footwell my friend tightened bolt with 10mm ratchet spanner while I held nut in place with S shaped ring spanner. Top bolt is easy with 13mm open end spanner on nut and 10mm 1/4 inch socket on 2 inch wobble bar extension and 1/4 inch ratchet on bolt in pedal box. So it’s all doable on a 2.4 or 2.2 TDCI without removing the clutch pedal box. just really tight and benefits from two people doing it. Note: On the original Girling MC the push rod is a finer thread with 13mm nuts, on the LOF MC the thread looks metric and first two nuts are wider and 14mm and the 3rd nylock nut is metric 13mm ! PS. Reminds me of a joke, Did you hear about that gynaecologist, he wallpapered his hall via the letter box. I think I could do that now ![]() Once bolted everything together and after bleeding the clutch the problem still exists, pedal goes to floor and stays there, clutch does not disengage. So it was worth a punt as there was no leak at the weephole at bottom of gearbox where it mates wiith the engine, but seems we probably have a slave cylinder issue. Well unless someone thinks it could be me not bleeding correctly. Views appreciated. |
