Home > Maintenance & Modifications > LOF Powermaster Install tips |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Do a search
11th Apr 2020 7:06am |
Double post
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3670 |
Thanks!!
Did that, didn’t find a great deal of detail other than reviews. Hence the post. |
11th Apr 2020 7:41am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2291 |
Do you mean the powermaster (master cylinder) or the powerspring (pedal spring)? Perhaps you bought the kit containing both parts?
Your post suggests it is the spring you are having trouble with, have a read through the following thread https://www.defender2.net/forum/topic66507.html > 110 XS Double Cab |
11th Apr 2020 7:56am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2216 |
Remove the clutch pedal box to change the master.
Straightforward mechanical job, bleeding the system can be challenging for novices. HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
11th Apr 2020 8:28am |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
^^^ That's what I did - pedal box out. Makes it a breeze really.
Mo - what do you mean it can be challenging to bleed for novices? Mine is bled, and working, but wondering if I've missed something, as I can have novice tendencies on occasion....! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
11th Apr 2020 9:00am |
Cheers guys, much appreciated. It is the powermaster I was talking about. I fitted the spring a while back.
11th Apr 2020 9:24am |
Don,
Challenging in respect that it can be difficult to bleed completely on first attempts. Once you've done a couple you know what to expect. I find driving it for a while helps, some like to hold down the pedal overnight or reverse bleed. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
11th Apr 2020 9:33am |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 |
Unbolt the slave cylinder, hang it downward with the bleed screw open ,
Press the pedal down and keep it there , keep topping up the fluid , shouldn’t be far away by then |
11th Apr 2020 11:29am |
Thanks - not aware I've had an issue really, but I did this recently as I had to change the pipe. All seems to be working fine - I was just curious.
Co1 - you'll love it when it's fitted. I have both the spring, and the powermaster, and the net effect is such an easy pedal. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
11th Apr 2020 5:48pm |
I don’t know what the hell im doing wrong, but I can’t even get the mats back to access the bolts for the pedal box!! LOF website reckons this is a 25 minute job!! I can only assume they’ve never don’t it on a puma! Once the pedal box is loose, does it even fit past the brake lines? |
18th Apr 2020 11:14am |
Co1,
The mats do get in the way ! I'm not sure how mats are secured in the puma. I done it up to TD5 and the rubber mats are secured by a metal strip across the bottom of the dash/ top of the footwell. The screws on the strip need slackening to allow the top edge of the rubber to be eased out and pulled down. This will then allow the pedal box bolts to be accessed. Be patient, work methodically. It's not difficult but does require thought especially if you haven't done it before. HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
18th Apr 2020 11:26am |
If you reach an impasse, step away, have a cup of tea, then have another look
18th Apr 2020 11:29am |
Cheers Mo. Not sure I’ve got enough tea bags!
18th Apr 2020 11:36am |
