Home > Puma (Tdci) > Room in the back. |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
You'd be better off with a Disco 4 Commercial - more room in one of them John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
19th Jul 2011 11:03pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
If you were on Mastermind your speciality would be... "the friggin obvious"? If you can't post helpful stuff don't post!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
19th Jul 2011 11:06pm |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 |
If you do remove them let us know how long it takes as I've heard various reports. 2008 110 XS CSW Stornoway Grey
19th Jul 2011 11:55pm |
Mine is a 90 CSW... much easier i would imagine than a 110? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
20th Jul 2011 12:07am |
Sorry RD, i've obviously missed something. How come with out sounding thick? 2008 110 XS CSW Stornoway Grey |
20th Jul 2011 12:19am |
Different seat configuration? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
20th Jul 2011 12:22am |
Both got 2 front facing seats at the rear? 2008 110 XS CSW Stornoway Grey
20th Jul 2011 12:32am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
I removed mine takes about one hour, you just need to note the spring configuration (take a photo), then seal up the holes with bolts and silicon. Best to put some WD40 or similar on the bolts that protrude into the wheelarch a couple of days prior to removal. It's a simple job. Original Member Pie n Pea Club.
110 HCPU Tipper |
20th Jul 2011 5:50am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5012 |
V10 has just asked the same question in maintenance & modifications........surely it's the easiest job in the world for a mechanic - no nasties involved! Are you thinking of flogging them separately to the vehicle.
20th Jul 2011 7:36am |
No Zag, they will be going back in just that at this time of year i need the room for putting out feed to my pheasant poults and the seats as yet are unused so i don't want to damage them. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
20th Jul 2011 9:13am |
No difference at all. They are exactly the same seats and fittings. There are many threads on here about it - just use the search function built in to the site. HTH John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
20th Jul 2011 9:30am |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Took mine out of the 110 and they are the same as the 90. Took about 30mins to do and mind they are heavier than they look, as my back found out I then put most of the fixing bolts back in and coated the exposed threads in waxoyl (aerosol can) and used rubber blanking grommets for the others. Back end has always been water tight and still is.
20th Jul 2011 11:00am |
Cheers Lorryman,
Thought i was going daft 2008 110 XS CSW Stornoway Grey |
20th Jul 2011 11:07am |
