![]() | Home > Puma (Tdci) > Room in the back. |
You'd be better off with a Disco 4 Commercial - more room in one of them
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
If you were on Mastermind your speciality would be... "the friggin obvious"? If you can't post helpful stuff don't post!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 ![]() ![]() ![]() |
If you do remove them let us know how long it takes as I've heard various reports.
Mine is a 90 CSW... much easier i would imagine than a 110? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Sorry RD, i've obviously missed something. How come with out sounding thick? 2008 110 XS CSW Stornoway Grey |
Different seat configuration? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Both got 2 front facing seats at the rear? 2008 110 XS CSW Stornoway Grey
I removed mine takes about one hour, you just need to note the spring configuration (take a photo), then seal up the holes with bolts and silicon. Best to put some WD40 or similar on the bolts that protrude into the wheelarch a couple of days prior to removal. It's a simple job. Original Member Pie n Pea Club.
110 HCPU Tipper |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5019 ![]() ![]() |
V10 has just asked the same question in maintenance & modifications........surely it's the easiest job in the world for a mechanic - no nasties involved! Are you thinking of flogging them separately to the vehicle.
No Zag, they will be going back in just that at this time of year i need the room for putting out feed to my pheasant poults and the seats as yet are unused so i don't want to damage them. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
No difference at all. They are exactly the same seats and fittings. There are many threads on here about it - just use the search function built in to the site. HTH ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Took mine out of the 110 and they are the same as the 90. Took about 30mins to do and mind they are heavier than they look, as my back found out
Cheers Lorryman,
Thought i was going daft ![]() |
