Home > Puma (Tdci) > Room in the back.
RED-DOT
Room in the back.
I am contemplating removing the 2 rear forward facing seats as a 90 CSW has no room and i have never used the things.. Anyone removed them then regretted it? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81112 19th Jul 2011 11:58pm
JSG
You'd be better off with a Disco 4 Commercial - more room in one of them Mr. Green John
2011 Tdci 110 CSW XS
Post #81117 20th Jul 2011 12:03am
RED-DOT
If you were on Mastermind your speciality would be... "the friggin obvious"? If you can't post helpful stuff don't post!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81119 20th Jul 2011 12:06am
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
If you do remove them let us know how long it takes as I've heard various reports. Confused 2008 110 XS CSW Stornoway Grey
Post #81123 20th Jul 2011 12:55am
RED-DOT
Mine is a 90 CSW... much easier i would imagine than a 110? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81124 20th Jul 2011 1:07am
Lukey Boy
Sorry RD, i've obviously missed something. How come with out sounding thick? 2008 110 XS CSW Stornoway Grey
Post #81127 20th Jul 2011 1:19am
RED-DOT
Different seat configuration? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81128 20th Jul 2011 1:22am
Lukey Boy
Both got 2 front facing seats at the rear? 2008 110 XS CSW Stornoway Grey
Post #81129 20th Jul 2011 1:32am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
I removed mine takes about one hour, you just need to note the spring configuration (take a photo), then seal up the holes with bolts and silicon. Best to put some WD40 or similar on the bolts that protrude into the wheelarch a couple of days prior to removal. It's a simple job. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #81134 20th Jul 2011 6:50am
Zagato
V10 has just asked the same question in maintenance & modifications........surely it's the easiest job in the world for a mechanic - no nasties involved! Are you thinking of flogging them separately to the vehicle.
Post #81148 20th Jul 2011 8:36am
RED-DOT
No Zag, they will be going back in just that at this time of year i need the room for putting out feed to my pheasant poults and the seats as yet are unused so i don't want to damage them. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81159 20th Jul 2011 10:13am
JSG
No difference at all. They are exactly the same seats and fittings.
There are many threads on here about it - just use the search function built in to the site.
HTH Cool John
Post #81160 20th Jul 2011 10:30am
Lorryman100
Took mine out of the 110 and they are the same as the 90. Took about 30mins to do and mind they are heavier than they look, as my back found out Whistle I then put most of the fixing bolts back in and coated the exposed threads in waxoyl (aerosol can) and used rubber blanking grommets for the others. Back end has always been water tight and still is.
Post #81170 20th Jul 2011 12:00pm
Lukey Boy
Cheers Lorryman,
Thought i was going daft Laughing 2008 110 XS CSW Stornoway Grey
Post #81173 20th Jul 2011 12:07pm
