Home > Puma (Tdci) > 2.2 fuel filter change procedure
UtilityTruck
Thought I’d put up a quick post on this subject because I couldn’t really find any info previously. The workshop manual isn’t much help either, information is vague suggesting you need to complete the low pressure fuel system bleed procedure after a filter change. Given the 2.2’s in-tank pump this felt unnecessary but I wasn’t sure! I also didn’t want to pre-fill the filter with diesel given the potential for injector damage.
A thread on the Australian LR forum gave me confidence I’d be OK without the fuel priming pump, so I cracked on.
I can confirm the 2.2 puma does not need the hand fuel priming pump connecting to replace the fuel filter, even when it’s attached empty. The only real thing to remember before starting for the first time is to turn the key to the accessory position to prime the fuel system and that the pump only runs for 10s at a time so you’ll need to turn the ign to acc, wait 10s while the pump runs, then key off and back to acc. I did that 10 times, but I couldn’t hear fuel circulating after the 7’th cycle.
I realise this isn’t new information for a lot of people, but it might help someone like me who couldn't find info! 2014 Keswick Utility 2.2
Post #807972 29th Dec 2019 6:11pm
Sulisuli
Always useful to have knowledge of other owners experiences Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #808001 29th Dec 2019 9:16pm
Roy5695
If you pre-fill the filter before fitting too you can save the priming business, just start as normal and leave running for 5 minutes! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #808009 29th Dec 2019 9:44pm
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
I prefill the new filter then start/run engine at about 3000rpm for one minute. Never had any problem.
Post #808036 29th Dec 2019 11:26pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Hello UtilityTruck,
Did it start up without any problem?
Did you increase the RPMs on start?
I don't like the idea of pre fuelling fuel filters just in case debris gets.
Thanks
Mark
Post #808471 2nd Jan 2020 2:33pm
Thon
Did my 2.4 a couple of weeks ago and pre-filled the filter with a fuel treatment / additive. Just fired it up and left it running for 5 Mins.
Post #808474 2nd Jan 2020 3:07pm
Isn't there an in built purge cycle like the Td5's have? (ign on, pump the throttle pedal 5 or so times and it'll run the pump constantly for a minute or 3)
Post #808497 2nd Jan 2020 7:18pm
UtilityTruck
Marks Landy wrote:
Hello UtilityTruck,
Thanks
Mark
Yes started as normal, no hesitation. No need to raise the revs at all.
The in-tank pump and return style fuel system mean all the air is purged back into the tank. Thumbs Up 2014 Keswick Utility 2.2
Post #808512 2nd Jan 2020 8:07pm
Marks Landy
Replaced my filter this morning and bleed as described, no problem.
Started up first time.
Much better then risking un filtered fuel getting in the HP pump while priming the filter.
Thanks UT!
Post #813066 1st Feb 2020 2:31pm
xjahx
United States 1997 Defender 110 300 Tdi SW Barolo Black
Worked flawlessly.
Post #813684 5th Feb 2020 1:47am
RichLech
For the avoidance of doubt, exactly which procedure did you use? There are a few procedures described in the topic.
Post #813709 5th Feb 2020 9:40am
Marks Landy
I followed UtilityTrucks advise at the start of the this thread, worked a treat!
Post #813711 5th Feb 2020 9:48am
JOW240725
Useful information, thank you for posting. Thumbs Up James
Instagram @suffolk_rovers
Post #813730 5th Feb 2020 11:05am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
hi,
I did want to purge the diesel filtre ...
Nothing was going out, so I decide to turn the key for 2 or 3 secondes ...
The key out, the cycle of pumping was going to the end.
My surprise was to see that with one cycle there was 0.6 litre in the container !
So I think that it is not neccessary to make 10 cycle, I will try with 3 next time I change the filtre
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #815997 19th Feb 2020 2:57pm
UtilityTruck
Interesting to hear Philippe, I was simply going on the sound, which changed on the 7th cycle so really I have no idea how many cycles were required to actually purge the filter- I played it safe I suppose! 2014 Keswick Utility 2.2
Post #816086 20th Feb 2020 12:58am
