![]() | Home > Puma (Tdci) > 2.2 fuel filter change procedure |
Island Rover Member Since: 15 Jun 2018 Location: Grenada, West Indies Posts: 14 ![]() ![]() ![]() |
I had a problem after installing the Gwyn Lewis fuel filter relocation kit on my 2008 Defender 110. Apparently, I was not careful enough while stretching the fuel lines the inch or two required and broke one of the nipples off of the fuel filter mount. Then, I wasn't careful enough when I was replacing the fuel filter mount and damaged the fuel line connectors.
So, I have just had to replace the fuel lines from the tank to the filter, the filter holder and fuel lines from the filter to the fuel cooler. The lesson here? BE CAREFUL!!! Problem now is that I have to really bleed the fuel system and being a 2.4 Puma, has no fuel tank pump. Yesterday I made my own fuel bleeder using the fuel line for an outboard engine (rubber hose with pressure bulb and one way valve) I attached it to the supply nipple on the engine side of the fuel filter and pulled fuel into the filter, then attached it to the low pressure pump supply hose using one of the connectors from the old fuel line. I was able to pull fuel up that far, but when I reconnected the fuel line, the engine still won't start... Going back to the shop again today to try again. Wondering if anyone has any ideas on what I might be doing wrong or any other ideas for me to get it bleed and started? Thanks! |
